It is currently Tue Oct 20, 2026 9:44 pm
Post Posted: Wed Nov 02, 2016 5:46 pm
Can someone please help, what does this mean.
I turned off the fan and hence the AC this afternoon while idling at the lights and wound the windows down. The green ac light flashed a few times, stopped flashing then flashed about once per second for about 15 seconds then went off.
What the hek is this?
Vehicle: 2006 2.7 prestige auto.
Post Posted: Wed Nov 02, 2016 10:02 pm
On the new NGV the recirc light flashes when the cabin filter is blocked. Check that out and see if that's the cause
Post Posted: Wed Nov 02, 2016 10:57 pm
An 04 should have the newer dash with three round knobs for the a/c controls - the flashing lights indicate a problem and there's a way to make them flash a code that pinpoints the problem - unfortunately I don't have the manuals for that year.
The problem is most likely related to one of selector blend doors not moving or not moving freely - fresh/recirculate, hot/cold and distribution.
Post Posted: Thu Nov 03, 2016 11:10 am
Yes this is consistent with other posts I've seen but it didn't happen till I turned it off. That's What is weird.
Can Anyone tell me how to extract the code and what they mean?
Post Posted: Thu Nov 03, 2016 11:15 am
I have the service manual but can't find anything about getting ac codes. Do You know what section it would be in?
Or Is it the same as getting engine codes, i.e.. need a code reader?
Post Posted: Thu Nov 03, 2016 9:58 pm
Check section 1B - HVAC - the Suzuki scan tool can be used and there should also be a way to get the a/c indicator to flash a code sequence.
Post Posted: Sun Nov 06, 2016 6:18 pm
Well this wouldn't have been helping.
Yep all that stuff on the ground was on the filter. Looks Like it's due for replacement too.
Vehicle: 98 Jimny
Post Posted: Sun Nov 06, 2016 6:20 pm
Wow! Definitely wouldn't of been helping. Has the issue persisted?
Side note; looks like there's a pink iPod in amongst the leaves! Haha
Post Posted: Sun Nov 06, 2016 8:02 pm
Lol i had the same thing happening to my GV but sold it before i found out what was the causing it.
Post Posted: Mon Nov 07, 2016 5:45 pm
If its the horizontal one, ryco BA falcon one squeezes in and is alot cheaper .
Post Posted: Thu Nov 24, 2016 6:02 pm
Light came on again today. Seemed like a sequence. 2 flashes a pause then 14 or15 flashes. Hard to count while driving.
Also I had codes checked on the weekend and nothing about the ac. The lights flashes on the same section of road as last time. 100ks for about 10min on the highway, then up hill for the last k. On the way up the hill the light stated flashing. I turned off the ac left the fan on. The light keeps flashing for about 5 sequences then stopped.
Post Posted: Sun Nov 27, 2016 3:59 pm
Losfer helped me put the hvac into diagnosis mode. Code read.
Thanks Losfer
Post Posted: Sun Nov 27, 2016 5:01 pm
No worries Max. Thanks for the facebook like
Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic.
Please like and share my facebook page - www.facebook.com/suzukimechanic
Post Posted: Thu Mar 09, 2017 4:51 pm
My wifes car started doing this today :( what did you guys find the problem to be?
Post Posted: Thu Mar 09, 2017 6:49 pm
Not enough 4wd engagement
Post Posted: Thu Mar 09, 2017 9:12 pm
Ummmm. Don't know. All I've done is replace the cabin filter.
The code suggested faulty HVAC sensor in the fan box I think from memory. But was advised expensive and not detrimental if only intermittent.
Now that I think of it I haven't had the problem since a few weeks after replacing the filter.
Post Posted: Thu Mar 09, 2017 9:39 pm
Ok ill start there cheers 300NA and Scrawny i reckon you could be onto it :(
Users browsing this forum: Google [Bot] and 228 guests
