It is currently Tue Oct 20, 2026 11:57 pm
Vehicle: 98 Vitara 2.0 Ragtop
Post Posted: Tue Jan 24, 2017 8:22 pm
Hi all
My 1998 2.0 Vitara occasionally turns on the check engine light. After a while it turns off again.
I have had it looked at be various mechanics and the result has always been "no idea maybe replace the O2 sensors" which they then tell me will cost $lots.
Anyone actually know what is going on here?
Post Posted: Tue Jan 24, 2017 8:24 pm
Most likely O2 sensor.
Vehicle: 1997 Suzuki sv420 vitara
Post Posted: Tue Jan 24, 2017 9:32 pm
Had same problem with my 97 2.0L replaced O2 sensor problem fixed.
Post Posted: Tue Jan 24, 2017 10:21 pm
sounds to me like the 1/2 inch square of duct tape has fallen off the dash screen ... ...
Post Posted: Wed Jan 25, 2017 12:50 am
Find a mechanic with a scanner that supports the SDL protocol - the cause of the check engine light is stored in the ECU memory and can be read by a compatible scanner, even after the light turns off, until the ECU is reset by disconnecting the battery.
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Wed Jan 25, 2017 5:31 am
Super cheap can do most. You Don't pay if they can't.$28 I think
Vehicle: zook
Post Posted: Wed Jan 25, 2017 7:36 am
Or find a paper clip, jam it in the connector under the bonnet to get the MIL to flash the code. Cost: 1 cent: Time 2 minutes
Will almost certainly be O2 sensor.
I don't think i paid more than$170 for the one I replaced in my GV
Post Posted: Wed Jan 25, 2017 11:29 am
If I recall correctly, the paper clip method won't pull the historic codes - no harm in trying it though.
Post Posted: Wed Jan 25, 2017 4:21 pm
$45 US plus postage from rock auto
Post Posted: Wed Jan 25, 2017 5:51 pm
Thanks guys. I will on to it over the weekend.
Post Posted: Wed Jan 25, 2017 6:52 pm
Link? I can't seem to find this.
Post Posted: Wed Jan 25, 2017 7:45 pm
Email them your VIN to confirm correct part. http://www.rockauto.com/m/mobilecatalog.php
Post Posted: Thu Jan 26, 2017 12:39 am
RockAuto will not list parts for a 98 Suzuki Vitara - their current focus is the North America markets and the Vitara was not available there in 98. Assuming that they can do a VIN lookup, which I suspect will fail because an Australian VIN does not follow the US VIN requirements (it typically returns an invalid VIN error), it will simply point them to a vehicle which is not listed in their catalogue.
Please also be aware that sourcing parts for "non-US" models in the US is not as simple as matching the model, year & engine size - different markets had different models offered with different engine options, introduced in different years and US models would have had to meet US emission requirements, which for the 98 model year, would have been unique to the US market - EFI systems & sensors are different.
This does not mean that parts cannot be sourced from the US, just that the onus is on you to ensure you're choosing the correct part, the US vendors will either tell you they don't have it, based on what they see in the computer, or sell you what the computer shows them.
Post Posted: Thu Jan 26, 2017 9:32 am
Super cheap is another option. I think it was about $75.
Us don't have the gv 2L 2004, but they were able to get me coil packs. A fraction of the price of anyone here.
Users browsing this forum: Google [Bot] and 172 guests
