It is currently Tue Oct 20, 2026 2:10 pm
Vehicle: Vit98 J20A SWB & Sierra89
Post Posted: Sat Feb 11, 2017 11:05 am
I have been searching here for threads on the sloppy gear lever, I had to change the bush and bolt in my sierra awhile back, I got the bush for that from ebay, some mob in Melbourne or Sydney I think, but I cant find any sign of bushes on ebay now? Who is best to source the bushes from? I will do the transfer stick bush too.... if I can find them....
Any links to threads on the subject would be handy too .... knowing the 98 2.0 it will be completely different from any other Vitara.... on these nuthin' is the same as nuthin' else ... :deadhorse:
It is a pita at the moment, can only get first, third and fifth.... there is not enough room for the stick to go back far enough to get the other gears (body lift),,, :roll:
Around Briz north or Sunny Coast would be handy :)
Post Posted: Sat Feb 11, 2017 9:39 pm
Unfortunately ive never seen aftermarket bushes for these , se416 and sv620 share the same parts as far as the gear lever system goes.
the suzuki part numbers for the 2 bushes for the gear lever are 28117-60A00 and 25551-60A02.
Ive seen this quite a lot ... quite often when the gear lever is removed the bottom bushing falls off the gear lever and into the housing , not in its seat. ive even heard of complaints of "sloppy lever and cant get it into 3rd gear etc" because the bush is jamming the select rod. Take the lever out and fish around in the housing to see if its in there somewhere.
Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic.
Please like and share my facebook page - www.facebook.com/suzukimechanic
Post Posted: Fri Mar 03, 2017 2:00 pm
Thanks, so where is the best place to get new bushes from? There is tons for Sierra, I even did my 79 Sierra bush and bolt, but I cant seem to find the bush for the Vitara.... whenever I search for the Vitara bush, Sierra bushes pop up :?
Post Posted: Fri Mar 03, 2017 2:39 pm
Thanks Losfer, I ordered those parts and they will have them in for me on Monday. I don't suppose you have the part number for the transfer case lever bush?
Also, do I need to get guide bolt(s) like on the sierra, they have the bolt that goes into the slot on the ball of the lever thru the side of the ball socket, to stop the gear lever rotating?
Post Posted: Fri Mar 03, 2017 3:20 pm
Check the slots on the ball isnt flogged out. I had to weld mine up and cut a new groove in my old vitara
Post Posted: Fri Mar 03, 2017 5:06 pm
I assume you have the 2 litre v6 yeah?
Sent from my SM-G935F using Tapatalk
Post Posted: Fri Mar 03, 2017 6:34 pm
sorry was on my phone you have the j20... transfer bush is 29535-60A00
Post Posted: Fri Mar 03, 2017 6:42 pm
the bolt in the gear lever and the transfer is the same as the sierra. 09135-08006
Users browsing this forum: Google Adsense [Bot] and 183 guests
