solid bench solid vice solid (and sharp) cold chisel ball pein hammer.. a solid one too Must have eye protection! Clamp the axle on an angle in the vice jaws so the collar is kind of upright but the bottom of the collar must also be touching the top of the vice jaws set the cold chisel on the top of the collar in line with the axle several good whacks on the chisel with your big hammer will stretch the collar slightly and it will loosen and then all you got to do is press the bearing off this way you can remove the bearing and not risk crap getting inside it
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
Posted: Thu Feb 23, 2017 12:38 pm
The last set I did the collars had 5 thou of inference!! Very hard to get on (used a bearing warmer and a ~15T press). Got no idea how you would get it off intact without destroying everything around it. Would not be keen in reusing it either.
Users browsing this forum: Google [Bot] and 237 guests
