It is currently Wed Oct 21, 2026 5:18 am
Vehicle: SJ51T
Post Posted: Wed Feb 22, 2017 1:17 pm
Anyone had any luck using a bearing puller or similar to get the collar off without having to grind and fuck it ?
Humble beginnings
Post Posted: Wed Feb 22, 2017 1:59 pm
Are you trying to reuse the collar because you pressed it on and forgot about the backing plate or being a tightarse?
I believe they are a use once only type item.
You could try a bearing separator, but grinding and chisel it pretty efficient and doesn't fuck anything, besides the bearing and collar.
Vehicle: Suzuki Vitara JLX
Post Posted: Wed Feb 22, 2017 4:58 pm
solid bench
solid vice
solid (and sharp) cold chisel
ball pein hammer.. a solid one too
Must have eye protection!
Clamp the axle on an angle in the vice jaws so the collar is kind of upright but the bottom of the collar must also be touching the top of the vice jaws
set the cold chisel on the top of the collar in line with the axle
several good whacks on the chisel with your big hammer will stretch the collar slightly and it will loosen and then all you got to do is press the bearing off
this way you can remove the bearing and not risk crap getting inside it
Vehicle: SJ51T
Post Posted: Wed Feb 22, 2017 10:52 pm
Im just being tight but i have done that before lol
Humble beginnings
Post Posted: Thu Feb 23, 2017 12:38 pm
The last set I did the collars had 5 thou of inference!! Very hard to get on (used a bearing warmer and a ~15T press). Got no idea how you would get it off intact without destroying everything around it. Would not be keen in reusing it either.
Lil Foot!
Post Posted: Sat Feb 25, 2017 5:31 pm
nah you never re-use a collar
Post Posted: Fri Mar 03, 2017 8:15 am
Agreed, that would be like using a condom again
Can be done but not worth the crying.
Mind you, if you want your axle to fall out, f#*kin go for it!!!!!! :peaceout:
Users browsing this forum: No registered users and 117 guests
