It is currently Tue Oct 13, 2026 12:13 pm
Vehicle: 2002 suzuki jimny
Post Posted: Mon Apr 17, 2017 5:54 pm
Thanks for info about wheel bearing, new ones are roller bearing not ball bearing like standard but has anyone used them and what torque did you do them up to , I think they are designed to bottom out with correct clearances.
What type of grease do you use for cv and pivot bearings moly or blue lithium sticky type grease or other?
Vehicle: LWB Sierra
Post Posted: Mon Apr 24, 2017 5:13 pm
Moly or wheel bearing grease is fine
Post Posted: Mon Apr 24, 2017 5:14 pm
Cv's require moly grease.
Vehicle: LWB Sierra
Post Posted: Thu Apr 27, 2017 11:10 am
Can you expand on that Steve
Post Posted: Thu Apr 27, 2017 11:12 am
Nothing to expand on really. Check the FSM. CV's don't use bearing grease. It's fine for the kingpins though.
Post Posted: Thu Apr 27, 2017 12:13 pm
If you used bearing grease on the kingpins would that mix with the cv grease and mess it up? Or wouldn't they be able to cross pollinate?
I've always used cv grease on the king pin bearings, that would be fine too no? As the king pin bearings don't rotate constantly like the wheel bearings.
I've also had a few 'knowledgeable folk' try sell a single grease (like that red sticky shit the sticks to everything, seriously I've used it outside and somehow it's magically stuck to my bed?!) as a 'one grease for both' solution. What's your take on that?
Post Posted: Thu Apr 27, 2017 1:17 pm
Im not too sure mate but the red stuff cant be good for you, keeping it out the bedroom would be my advice
Vehicle: LWB Sierra
Post Posted: Thu Apr 27, 2017 4:53 pm
I'll rephrase, is wheel bearing grease bad for CVs?
Post Posted: Thu Apr 27, 2017 5:07 pm
Post Posted: Thu Apr 27, 2017 8:30 pm
Because of the torque loading on the bearing surfaces when operating under power and at an angle, CV joints require a grease with extreme pressure additives - the most common is molybdenum disulfide - if there was nothing else available and you had to get home, wheel bearing grease would be better than no grease, but in the long term use of wheel bearing grease will result in premature failure of the CV joint.
Post Posted: Fri Apr 28, 2017 1:01 pm
Since when is lubrication in the bedroom ill advised? :D
Post Posted: Fri Apr 28, 2017 1:10 pm
Hmm
Bum stain justifying lube stains left in his bedroom, a little too much info
Post Posted: Fri Apr 28, 2017 4:15 pm
Lol!!
Users browsing this forum: No registered users and 166 guests
