It is currently Wed Oct 21, 2026 1:44 am
Vehicle: 2002 suzuki jimny
Post Posted: Thu Apr 13, 2017 7:35 pm
Is there a wrong freewheeling hub for my jimny as it seems to hard or costly to fix a seal in auto hub as you have to buy whole hub $666 each.I have looked on ebay and there are heaps but don't say for jimny after 1998 , mine is a 2002 model also is that all I need and gasket of course . Does anyone know where I can get a front wheel bearing hub besides genuine $223 as outer wheel bearing shell was moving inside hub housing no longer press in more like drop in. thanks in advance.
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Apr 14, 2017 5:47 pm
I am not sure exactly what the question is but you can fit Sierra manual hubs to a Jimny. You need to either grind off thee metal rim that seals the vacuum hub or use a BenT adapter ring. You can find them in the advertisers section. They come with the longer bolts you will need.
Post Posted: Fri Apr 14, 2017 6:11 pm
Glue the bearing in with locktight bearing glue and fit Sierra or vitara FW hubs.
Post Posted: Sat Apr 15, 2017 9:45 pm
Would you have a pic of what to grind off thanks?
Post Posted: Sun Apr 16, 2017 4:38 pm
Need to cut down the outside bit of the nut. It's bugger all, from memory it's only about 3mm or so.
Can also use a vitara bearing nut which needs no mods to fit.
Post Posted: Mon Apr 17, 2017 5:34 pm
thanks for that that's easy ill grind down edge
Users browsing this forum: No registered users and 220 guests
