Joined: Tue Dec 15, 2009 10:30 pm Posts: 11 Location: ipswich,qld aus
Vehicle: 2002 suzuki jimny
Posted: Thu Apr 13, 2017 7:35 pm
Is there a wrong freewheeling hub for my jimny as it seems to hard or costly to fix a seal in auto hub as you have to buy whole hub $666 each.I have looked on ebay and there are heaps but don't say for jimny after 1998 , mine is a 2002 model also is that all I need and gasket of course . Does anyone know where I can get a front wheel bearing hub besides genuine $223 as outer wheel bearing shell was moving inside hub housing no longer press in more like drop in. thanks in advance.
I am not sure exactly what the question is but you can fit Sierra manual hubs to a Jimny. You need to either grind off thee metal rim that seals the vacuum hub or use a BenT adapter ring. You can find them in the advertisers section. They come with the longer bolts you will need.
Posted: Sat Apr 15, 2017 9:45 pm
Users browsing this forum: No registered users and 291 guests
