It is currently Sun Oct 11, 2026 4:29 am
Vehicle: 2011 Jimny
Post Posted: Wed May 24, 2017 2:51 pm
There are quite a few cheap Jimny snorkles for sale on Ebay (around $100).
Has anybody fitted one of these?
Are they of a 'you get what you pay for' quality standard and better avoided?
Post Posted: Wed May 24, 2017 6:13 pm
I can't speak for Jimny ones but I have an eBay snorkel on my Landcruiser. Quality wise it's great, much sturdier than the factory Toyota snorkel.
I wouldn't buy one that's fibreglass (there's a few out there), to prone to cracking and can't take the knocks that plastic can.
Post Posted: Wed May 24, 2017 6:25 pm
I put one on my facelift jimmy and it was fine. Just be careful with the template as they are a bit hit and miss.
Vehicle: 2011 Jimny
Post Posted: Fri May 26, 2017 8:58 am
Thanks for the feed back.
Looks like an Ebay one it is.
Vehicle: Suzuki Jimny - 2017
Post Posted: Sat Jun 03, 2017 5:43 pm
Shep, can you link us the seller you bought yours off?
Post Posted: Sat Jun 03, 2017 6:24 pm
It was 3 years ago so wouldn't have a clue who I bought it off. The one I got is the one with "jimny" on it.
They don't advertise as fitting the facelift models but it's pretty simple to fit.
Vehicle: 2011 Jimny
Post Posted: Thu Jun 08, 2017 9:24 pm
I am fitting one I bought from wildplanetimport on Ebay. It was just over $80 delivered. (Ebay special with $20 discount)
It looks good and solid. I can't fault it for the price. The template is spot on - I have a 2011 Jimny without the turbo looking bonnet.
It involved removing the inner lining from the mudguard to get at the mounting bolts. There is also a canister ( some air or vacuum related item I think) fitted inside the mudguard which I needed to undo before I could remove the existing air intake thingy. All this is easier without the RHS front wheel and the battery. I test fit the snorkel and found it all good. I painted the holes I drilled and cut, and will reassemble everything tomorrow. Oh, I locktighted the supplied 6mm studs into the snorkel body to avoid having them coming loose later and will silicone the entry point into the aircleaner body.
No dramas..
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 271 guests
