It is currently Thu Oct 08, 2026 10:45 am
Post Posted: Sun Dec 04, 2011 11:12 am
Hi All,
Has anyone ever had issues with engaging low and high range gears.
I seem to have to play around till it will engage
Can the linkages be greased or do they get play in them?
Also noticed in low range the gearbox is a little whiney.
Are these cheap to repair?
Vehicle: Coil Sierra
Post Posted: Sun Dec 04, 2011 11:26 am
If it hasnt been used for some time it will be tight to find 4H and 4L, mine whines too, only n 4L.
Post Posted: Sun Dec 04, 2011 11:51 am
Check the oil level. If whine persists go for a drive without your Mrs in the car.
:P
Post Posted: Fri Mar 23, 2012 10:05 am
i have problems with my sj80 transfer box. i can change from 2h to 4h but cant get into neutral or 4l......are they easy to fix and cheap or dont worry bout it
Post Posted: Fri Mar 23, 2012 10:16 am
FWIW change it to a leafy case. At least you can gear it later.
Post Posted: Fri Mar 23, 2012 10:37 am
Have you pulled the shifter stick out and inspected the shifter bush underneath? They degrade over time and can cause this exact issue. Sometimes they even prevent the stick from being moved at all.
$10 part :wink:
Post Posted: Fri Mar 23, 2012 8:57 pm
$10 part :wink:
sj80 has no shift bush. :roll: :roll:
Post Posted: Fri Mar 23, 2012 8:59 pm
Ha ha... coilies suck.
Vehicle: SJ80, SE416
Post Posted: Fri Mar 23, 2012 10:57 pm
Hi Sman,
Sounds normal if the 'transmission is wound up' and the transfer box is tight - such as if you have been in high range for a while on hard surfaces and then want to select low. If this is the case, try reversing a couple of metres or driving forward in a zig-zag to take the pressure off the gears.
Low range will always whine - that is normal.
Reubs
Vehicle: SWB GV
Post Posted: Sat Mar 24, 2012 9:39 pm
I have had this issue before and did exactly as reubs suggested and still could not get it to engage. Wheeled for an hour in 4H and randomly tried to change into 4L and didn't have an issue in engaging.
Post Posted: Sat Mar 24, 2012 9:42 pm
if the car has a body lift the tranfer shifter maybe hitting the underbody metal due to the new angle
Vehicle: Suzuki SJ80
Post Posted: Mon Jul 31, 2017 5:00 am
sman wrote:
Hi All,
Hi, did you ever find out and fix your 4 low gear problem..I have the same problem with my SJ80 Sierra..and can't find a solution..appreciate your help
John
Limassol, Cyprus
Vehicle: zook
Post Posted: Tue Aug 01, 2017 10:33 pm
sman came and went, in 2011
Users browsing this forum: No registered users and 133 guests
