i got 160 in three cylinders and 170 in another, g13bb, is it still pretty good ? trying to work out if the valve stem seals and leaks are my only oil eating issue.
sam
was the test done on a cold or hot engine,wet or dry test?
All good there Sam nothing to worry about all within 10% that is what lula's has been on since we got it.
as Josh said doing it wet or dry can make up the differance.
DRY = Cranking the motor only Hot
Wet= Cranking it with throttle down. Hot
Same can be done with cold engine = Lower reading.
Also to check rings are Ok place a squirt of oil in the plug hole and test if it rises alot the rings may need attention Eg : 120PSI Dry Oil added 170 PSI
_________________ Steve W
Users browsing this forum: No registered users and 132 guests
