It is currently Tue Oct 20, 2026 10:44 pm
Post Posted: Mon Jul 13, 2009 10:11 pm
i got 160 in three cylinders and 170 in another, g13bb, is it still pretty good ? trying to work out if the valve stem seals and leaks are my only oil eating issue.
sam
Post Posted: Mon Jul 13, 2009 10:28 pm
mine has around 195-200 in all cylinders so that may be a little low but i dont know about the rest
Post Posted: Mon Jul 13, 2009 10:50 pm
around 200 is ruffly 10:1 compresion,you probably have 8.5:1 or around there,I dont htink there is anything to worry about?
Coily GTI Turbo...thats right its a coily!!
Post Posted: Tue Jul 14, 2009 12:03 am
sam
was the test done on a cold or hot engine,wet or dry test?
Post Posted: Tue Jul 14, 2009 12:44 am
All good there Sam nothing to worry about all within 10% that is what lula's has been on since we got it.
as Josh said doing it wet or dry can make up the differance.
DRY = Cranking the motor only Hot
Wet= Cranking it with throttle down. Hot
Same can be done with cold engine = Lower reading.
Also to check rings are Ok place a squirt of oil in the plug hole and test if it rises alot the rings may need attention Eg : 120PSI Dry Oil added 170 PSI
Steve W
Post Posted: Tue Jul 14, 2009 1:20 am
well it was cold and dry, so looks like it is pretty good still :)
did not want to do a timing belt if i was going to have to pull it apart later
Users browsing this forum: Google [Bot], ProteinDrinker and 239 guests
