It is currently Mon Oct 19, 2026 3:11 am
Post new topic Reply to topic  [ 29 posts ]
Vehicle: 2006 suzuki jimny
Post Posted: Fri Sep 27, 2019 7:41 pm
Im looking for a 10mm drain key socket for the gearbox/diff ect drain and fill bolts but i cant find one anywhere,
I found the part number for the socket suzuki uses in there manual but havent seen if suzuki can get one in or how much it would be. Does anyone no where to purchase one?
Post Posted: Fri Sep 27, 2019 8:15 pm
eBay search 10mm square key
They have small
Lengths of steel key then mosh mash up something in your garage to give it some leverage
Vehicle: Suzuki sierras
Post Posted: Fri Sep 27, 2019 9:04 pm
Just use a 3/8 drive ratchet.
Cheers Jack
Post Posted: Sat Sep 28, 2019 8:51 am
Cheers Jack
Which is an excellent way to trash the drain plug and have to weld a nut on.
3/8 drive ratchets are both smaller (3/8" being 9.6mm) and the corners are bevelled at the end to make it easy to get sockets on and off. the result is when you put them into a sharp, 10mm drain plug they want to back out and turn, wrecking the plug.
If you want to use a 3/8 drive, use a 1/2"X3/8" adapter and grind the end flush to remove the bevel, make sure there is no debris in the plug, and push HARD on the tool as you're trying to undo it.
The generic dog-bone shaped square drive tools I've seen are garbage. Cheap cast construction and the drives are tapered which is worse than terrible.
you can also use 10mm key steel which is very strong, dimensionally accurate and has sharp corners.
Post Posted: Sat Sep 28, 2019 10:34 am
I got a set of about 20 different 3/8" drive sump plug sockets including a 10mm square off ebay for $30ish. Handy set to have. I ground off the chamfered end of the 10mm square to get a bit more purchase on the bullshit shallow suzuki bungs.
The 10mm square is worth having. I had to use mine with a rattle gun and I totally changed the shape of the bung but it still gripped. I was never going to get it out with a breaker bar, maybe with heat.
Before I had the proper set I had a piece of sheet metal bent into an L to take up the extra clearance with a 3/8 drive extension bar with the chamfer ground off. It was a PITA but it got me out of a bind.
Post Posted: Sat Sep 28, 2019 2:20 pm
The 3/8s drive I used was quite square but I must have got lucky as all the ones I've done so far where not very seized.
Post Posted: Sun Sep 29, 2019 8:29 am
Here's the problem in photos.
Here's a typical WT diff fill plug. It's previously had a nut welded to it because someone attempted to undo it with a 3/8
Here's a Kinchrome 3/8" extension fully seated in the plug and rotated 45˚
at which point it just backs out, makes a mess of everything and a nut gets welded on.
Post Posted: Wed Oct 02, 2019 10:21 pm
A last resort, is to use a sharp cold chisel & punch a nick in the outside of the plug & then turn it round.
Careful to not also nick into, or bend the diff pan - only works on these 'external' flanged diff drain plugs.
If it is a gearbox or transfer box plug, welding on a nut is the go.
Either way means you need to find a replacement plug.
Rgs, Michael
Vehicle: 2011 Jimny
Post Posted: Sun Oct 13, 2019 2:27 pm
I bought a set of sump plug socketsin a kit from Super Cheap Autos. I can't remember exactly but around $35 I think.
Post Posted: Sun Oct 13, 2019 7:04 pm
I ended up finding one online from a tool shop cost me $20 for the socket, didnt realise how hard it would be to get one
Post Posted: Sun Oct 13, 2019 7:11 pm
I seen that on there website for $45 but they had none in stock
Vehicle: SJ51T
Post Posted: Mon Oct 14, 2019 5:48 am
i got key steel from a bearing shop for like $12
Humble beginnings
Post Posted: Sat Oct 19, 2019 5:45 pm
https://www.toolking.com.au/sump-plug-a ... ch-8-10mm/
Vehicle: Coily.
Post Posted: Mon Oct 21, 2019 8:25 am
Bruce wrote:
https://www.toolking.com.au/sump-plug-and-gear-box-square-drive-wrench-8-10mm/
Wrong link....i'll be back.
Post Posted: Mon Oct 21, 2019 3:01 pm
?????? What's wrong with it? Works for me.
Post Posted: Mon Oct 21, 2019 4:38 pm
Try this one. Same Same
https://www.ebay.com.au/itm/Sump-plug-a ... 1438.l2649
i'll be back :roll:
Vehicle: Coily.
Post Posted: Wed Oct 23, 2019 1:03 pm
i'll be back :roll:
Yes,that's the Ebay link,it didn't show in my searches over the years but i put in the sellers description from the website(above) and it was the first cab off the rank.
Now i'll just have to wait to see if it works,depends on machining and the quality(hardness) of the steel used.
Post Posted: Wed Oct 23, 2019 3:59 pm
Yeh i saw that one but i wanted a socket type one, i ended up finding one
Post Posted: Wed Oct 23, 2019 4:34 pm
You got a link or info on what you got please.
Post Posted: Wed Oct 23, 2019 4:41 pm
Te tool socket, its looks well built and the socket is nice and small to fit into tighter spots.
Costs me abit more bit i wanted a socket style one. They have a website to its called, australian online car parts.
https://rover.ebay.com/rover/0/0/0?mpre ... 2606701249
Post Posted: Wed Oct 23, 2019 4:55 pm
Thank you
Post Posted: Wed Oct 23, 2019 4:59 pm
Bruce wrote:
Thank you
No worries
Post Posted: Wed Oct 23, 2019 5:01 pm
You talking this site?
https://www.onlineautoparts.com.au/?gcl ... _EQAvD_BwE
Because I can't see it on that site? Sorry.
I only ask because I sort of know the owner (In a way through work)
Post Posted: Wed Oct 23, 2019 5:06 pm
No, this would be it :-)
https://www.australianonlinecarparts.com.au/
Post Posted: Wed Oct 23, 2019 5:12 pm
Bruce wrote:
Yeh thats the one, i think there ebay link says something different but its the same place, ill try find it on the site for you :)
Post Posted: Wed Oct 23, 2019 5:13 pm
All good found it.
Post Posted: Wed Oct 23, 2019 5:27 pm
Bruce wrote:
All good found it.
No worries :)
Post Posted: Wed Nov 06, 2019 5:56 pm
Well received one of these today. Great fit. JMO
Post Posted: Wed Nov 06, 2019 6:05 pm
Definitely fits well
Users browsing this forum: No registered users and 244 guests
