It is currently Tue Oct 20, 2026 12:31 pm
Vehicle: Suzuki sierras
Post Posted: Sat Oct 26, 2019 8:41 am
G'day you can't get air lockers for 1l axles can you?
if not will nt 1.3 axles bolt straight into a 1l?
Cheers Jack
Post Posted: Sat Oct 26, 2019 8:58 am
No and no almost sort of.
You can get auto lockers for 1.0 axles.
To swap to 1.3 axles you’ll need u bolts, spring plates, and a way of sorting driveshaft or transfer flanges. It’s worthwhile if you go WT, not really worth it if you stay narrow track.
Post Posted: Sat Oct 26, 2019 1:45 pm
thanks steve why is wt worth it but nt not?
Post Posted: Sat Oct 26, 2019 3:49 pm
Because the cost and work to do the job is basically the same for WT or NT, but NT axles have less aftermarket support, and you don't gain the stability, tyre clearance or steering clearance that WT axles offer.
When my car still had 1.0 axles under it I welded the rear and put 1.3 NT front axles in it. It ran fine like that with 34" tyres on it until I went to WT sierra axles.
if you have the budget to go to airlocker(s) go WT, 26 spline front and rear lockers both front and rear.
Post Posted: Sat Oct 26, 2019 4:01 pm
will wt housings be more likely to bend under a nt?
and would standard nt axles snap with 30/31s and lockers?
thanks for all the help
Cheers Jack
Post Posted: Sat Oct 26, 2019 4:21 pm
No. jumping the car, especially in sand, will bend front housings. It's otherwise not a significant problem.
Rear won't be a problem up to about 33" tyres, but it's definitely possible to break a front CV with 31's and lockers. It's not uncommon. there are no off the shelf NT 26 spline inner axles to work wth aftermarket cromo CV's.
31's will be all over your inner guards and shock mounts if you stay narrow track.
Post Posted: Sat Oct 26, 2019 5:08 pm
could you run 700 16s on a nt
Post Posted: Sat Oct 26, 2019 5:16 pm
when putting 1.3 axles in can you put reduction gears in a 1l transfer case or do you have to swap to a 1.3 transfer as well?
Cheers Jack.
Post Posted: Sat Oct 26, 2019 8:06 pm
Post Posted: Sun Oct 27, 2019 10:40 am
If it's a light switch 1l transfer then you can fit crawler gears. Most crawlers gears reuse the 1.3l low range output gear so you may have to source one of those. Gears like the 6.4s or 6.5s replace all the gears in the transfer so it doesn't matter there.
If it's a non switched transfer then you're fucked and you've got to swap it out.
Vehicle: LJ50V, SJ70
Post Posted: Mon Oct 28, 2019 11:09 pm
The Chinese e-locker/LSD comes in 1.0/LJ diff sizes. Might be an alternative to an Air Locker.
viewtopic.php?f=5&t=55719
Post Posted: Tue Oct 29, 2019 6:18 pm
Whats an auto locker like to live with? I've been reading and they seem to be a love or hate thing.
Cheers Jack.
Post Posted: Tue Oct 29, 2019 8:37 pm
Ok for the price....
Post Posted: Tue Oct 29, 2019 10:27 pm
Cheers Jack.
Is the car used on road?
Post Posted: Wed Oct 30, 2019 3:13 pm
yes it will be.
Post Posted: Thu Oct 31, 2019 9:44 pm
Jack jr wrote:
yes it will be.
If you drive on road go air, I used to daily my coily with a Spool, then drove my leafy to wheeling with a spool, now I just trailer it to parks and travel in the luxury of a tow car. having a spool/weldy/auto in the rear is cool at first but really gets to you after a while.
Users browsing this forum: No registered users and 201 guests
