Joined: Sat Aug 13, 2011 11:44 pm Posts: 63 Location: bairnsdale
Vehicle: 1973 lj50 fully restored
Posted: Tue Oct 29, 2024 2:20 pm
I am fitting a LJ80 motor to a lj50 for a friend and I was wondering if the LJ80 diff centers will fit in the LJ50 housing to give a higher ratio for the 4 stroke motor also are the splines the same.
Joined: Sun Nov 16, 2008 10:30 pm Posts: 301 Location: NZ
Vehicle: LJ50 , LJ80Q-II
Posted: Thu Oct 31, 2024 4:16 pm
The diff head will bolt straight in , however the rear axles on the LJ80-II are larger , so the LJ50 axles likely won’t match the lJ80 centres. Pretty sure the front has a similar issue .
I know you can fit LJ80 spider gears into lJ50 centre carriers to run 4.88 ratio diff in a Lj80 so would assume you could fit Lj50 spider gears into a lJ80 centre carrier to run the 4.55 ratio diff in a lJ50
Personally I would just fit bigger tyres on the LJ50 to account for the slight gearbox ratio differences .
Users browsing this forum: Google [Bot] and 169 guests
