It is currently Mon Oct 19, 2026 10:39 pm
Vehicle: Grand vitara
Post Posted: Tue Nov 25, 2025 6:37 am
Gday all
We have a 2010 grand vitara which has developed a fault in the abs system. The code is C1044.
The internet searches ive done show several possible causes, including abs module faults, dodgy soldering in the unit & right rear wheel speed sensor problems.
Has anyone here experienced this fault, & if so, how did you fix it?
TIA.
Vehicle: 2009 SUZUKI GRAND VITARA 2.4L
Post Posted: Wed Jan 21, 2026 10:02 pm
Hi Bazzasuzuki,
I have the same problem with a 2009 GV.
Dealer Service department said to replace the unit at $5k which is ridiculous.
Have you had any luck?
I’m starting down the sme path s you.
Vehicle: 2008 grand vitara prestige
Post Posted: Sat Apr 11, 2026 1:41 pm
mark.k wrote:
Hi Bazzasuzuki,
I have the 2008, weak battery. I changed the battery to a new one and all good.
If your abs service message goes out after the car starts that's likely the cause.
Users browsing this forum: No registered users and 231 guests
