It is currently Tue Oct 20, 2026 4:03 pm
Post Posted: Sun Aug 02, 2009 11:45 pm
I pulled down my new engine today its a g16a but it has 16 valve pistons in it. I am running the 8 valve headand it has run like this as its a second hand engine.
My question is why would it have 16valve pistons in it?
and will it cause damage eventually?
also can i use a sierra 1.3 fuel pump in the 1.6 head
cheers jesse
Post Posted: Sun Aug 02, 2009 11:50 pm
I've found 16 valve pistons in G16A blocks too, it won't do any damage.
Not sure if the fuel pump fits the G16 head?
Post Posted: Sun Aug 02, 2009 11:59 pm
is there a compression difference in the 2 different pistons?
also do 1.3 extractors fit the 8 valve head
Post Posted: Mon Aug 03, 2009 12:02 am
Damo can tell you what the differences are. There are 3 types that I know of, 8v, 16v shallow dish and 16v deep dish
Post Posted: Mon Aug 03, 2009 12:15 am
IMPORT 1.6 engines, regardless of being TBI, 16 valve or carby are all G16A. Only in Australia is the efi designated a 'B'.
Post Posted: Mon Aug 03, 2009 12:26 am
thanks joe that helps i couldnt figure it out.
Anyone know if i can use my 1.3 extractors on the 8 valve head and extend them for the taller block?
jesse
Post Posted: Mon Aug 03, 2009 12:32 am
1.3 fuel pump fits with an adapter plate, and 8 valve 1.3 extractors will fit
this is an 8 valve 1.6 head with existing extractors and fuel pump that came on the standard motor.
you can just see the plate i made for the fuel pump, sorry only pic i have from the old motor
Post Posted: Mon Aug 03, 2009 12:45 am
Thanks for that saam i should be able to work that out.
jesse
Users browsing this forum: No registered users and 210 guests
