ARG i can't find the earth wire for the head lights??? There is one just under the windscreen wipers in the engine bay but tthats the only one i've found loosely related to the head lights... i pull the back off the bright head light and the other one goes bright then i connect them again and they both work high beam and low beam... then when i try again the light thats dull is good then it goes crazy again choosing when it want's to work...grrr
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
Posted: Wed Aug 05, 2009 5:03 am
Run a new seperate earth for each headlight!?!?
try the link, it has a great diagram relating to spotlights but will work the same way.. hell maybe you might want to wire the spotties up while your at it!!
Users browsing this forum: No registered users and 230 guests
