It is currently Wed Oct 21, 2026 3:41 pm
Vehicle: MY2019 Jimny
Post Posted: Sun Aug 09, 2009 5:56 pm
I tried to get the front diff drain plug undone, but the last few people to do it munted it so badly it now has a round hole instead of square...
ANyway I'll get my mechanic to weld a nut on and remove it.
The bit I need help with is which drain plug it can be replaced with that is not a square hole type, but an external hex type. I heard a while back that there was a magnetic one around, but couldn't find which one it is...
Post Posted: Sun Aug 09, 2009 6:18 pm
weld a nut to the plug and then put a brass washer on it and keep using it. mine has been undone stacks of times since i fixed it.
Post Posted: Sun Aug 09, 2009 10:16 pm
i think one of mine is magnetic, so they are deffinately around. might be the transfer plug?
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Post Posted: Sun Aug 09, 2009 10:20 pm
All mine are magnetic, but I am after a hex shaped one, not a square key..
Post Posted: Sun Aug 09, 2009 10:23 pm
does yours have a flat surface for a seal or is it the tapered one?
Any hydraulic/pnematic place should have a new grubscrew to suit your needs, or try boltmaster up the rd from yours.
Or u can eat my dick and i will give you one :wink:
Unsure about the hex/bolt head ones..
Post Posted: Sun Aug 09, 2009 10:26 pm
I could tell you if I could get it out!
Post Posted: Sun Aug 09, 2009 10:27 pm
Hmm tempting, but I try not to snack...
Post Posted: Sun Aug 09, 2009 10:39 pm
May be have a look at LJ one's . :wink:
Post Posted: Sun Aug 09, 2009 11:30 pm
you don't need it out to see what type it is.
if it is the type that has a flat to seal on the outside of the diff housing
they come out easy as if you give it a tap with a cold chisel. :wink:
Users browsing this forum: Google [Bot] and 104 guests
