It is currently Tue Oct 20, 2026 11:58 pm
Vehicle: 1999 Jimny
Post Posted: Mon Aug 10, 2009 12:18 am
As the topic says, Alright Gurus let me have some wisdom!!!!!!!!!!!!!!
Post Posted: Tue Aug 11, 2009 1:28 am
Hmmm - AWshifting.com used to be the source for paddle shifting AW Boxes but they seem to have vanished - the site has disappeared.
Constant power is required to the chosen solenoid. I'm aware of a "temporary" setup on an AW-4 behind a motor with no computer interface with the auto (might as well be carby) that uses a 4 position knob to select the gear you want - quite an easy solution.
However, there's some catches. This is fully manual. Pull up in 4th, and it will try and pull away in 4th. This might be a pita.
Moving the t-bar shifter into the 2 or 1 positions will do strange things, including with the torque converter lock.
You'll have to work out how to control or disable the torque converter lock. should you want to.
Just noticed this.
Manual shifting solutions for automatic transmissions
AWshifting is changing.
By January 2009 AWshifting will be open source under a Creative Commons license. No more orders are being accepted, and the next few weeks will be spent catching up on backorders. What does open source mean? That means all the information to create your own AWshifting controller will be posted right here on this site. That's right, all of it. From parts lists to programs, you can make your own.
http://awshifting.com/index.html
I might have a play with that when the info is available. The downside is that it looks pretty simple though, not a patch on Suprastick.
Vehicle: 1999 Jimny
Post Posted: Tue Aug 11, 2009 1:36 am
Hmmm seems like we might need a computer guru for this mod then.......
Post Posted: Tue Aug 11, 2009 1:56 am
all other sensors to the engine can be hooked up with a little work, the MAIN drama is converting tps voltage signal from the throttle body into a 'duty cycle' signal for the auto comp. once this is done its quite easy to wire up with available sensors.
check out my posts.....i have listed my own diagram for the AW4.
Vehicle: 1999 Jimny
Post Posted: Tue Aug 11, 2009 9:46 am
links??? save a lazy bastard the search................ :please: :rofl:
Post Posted: Tue Aug 11, 2009 12:30 pm
http://www.auszookers.com/index.php?nam ... pic&t=5198
Post Posted: Tue Aug 11, 2009 2:28 pm
Do you know what frequency and % duty cycle range is needed? I could help with mocking up this if required.
Dan
Post Posted: Tue Aug 11, 2009 3:12 pm
will have a look at the factory book and see what details it has.
Vehicle: 1999 Jimny
Post Posted: Fri Aug 14, 2009 8:26 pm
Hey Joe, how about that copy of the diagram mate....................
Users browsing this forum: Google [Bot] and 170 guests
