It is currently Wed Oct 21, 2026 2:53 pm
Post Posted: Mon Aug 03, 2009 5:25 pm
Hey,
just wondering what people have done to upgrade there fuel tanks to something bigger?? I have a sierra ute and it only has got a 40 L tank and it doesn't last that long as i have got a toyota 5k motor.
let me know what tank you have used.
86 LWB Sierra Ute
Toyota 5k with Toyota 5 speed
Post Posted: Mon Aug 03, 2009 6:45 pm
http://www.thelongranger.com.au/sierra9 ... ltank.html
That's what I have in Casper. 70lt tank
Post Posted: Mon Aug 03, 2009 9:42 pm
how much are they worth, th they hang down at all?
Vehicle: SJ80
Post Posted: Tue Aug 04, 2009 2:39 am
Am considering the same.
Have a SJ80 that I hope to put a fuel injected motor in, sometime in the far distant future.
Contemplating getting a larger tank out of a car that has a high pressure fuel pump, combined with the sender/pickup assembly.
I don't even get 40 L with the stock tank, a good 6-8L are taken up in dents.
Post Posted: Tue Aug 04, 2009 2:48 am
chadd1981 wrote:
Hey,
Get a carby pajero fuel tank. Should be less than $100 from wreckers. They are 83L and fit perfectly between the rails on a ute. I will take some pics of mine in the morning.
Pete
Post Posted: Wed Aug 05, 2009 7:40 pm
chadd1981 wrote:
Hey,
Pete
hey Pete,
have you been able to take photos of your tank yet?? What year pajero are these in??
86 LWB Sierra Ute
Vehicle: SJ80
Post Posted: Fri Aug 07, 2009 3:30 am
Ok... so do injected pajero tanks fit? a non ute zook?
A coily zook?
Yes, photo's would be wonderful...
Post Posted: Fri Aug 07, 2009 6:18 am
+1 , Interested in this aswell!
Post Posted: Fri Aug 07, 2009 11:55 am
can't host at the moment. PM me with your email address and I will forward pics.
Post Posted: Fri Aug 07, 2009 9:42 pm
If anyone can post up Fatzooks photo's that would be good. Saves him having to email 1000 people ;)
Post Posted: Fri Aug 07, 2009 11:39 pm
Ummmm ...... photobucket????
Post Posted: Sat Aug 08, 2009 12:06 am
http://tinypic.com/r/10wky38/3
http://tinypic.com/r/nnochz/3
http://tinypic.com/r/2gxh20j/3
Vehicle: SJ80
Post Posted: Mon Aug 10, 2009 4:13 am
Ok - so those were photos of a Pajero tank in a Sierra Ute?
Utes are longer than soft tops arn't they? anyone know if a Pajero tank would be likely to fit in a soft top SJ80?
Post Posted: Mon Aug 10, 2009 9:02 am
Depends on the location of the filler neck on the tank. I'd be interested to know as well
Vehicle: SJ80
Post Posted: Thu Aug 13, 2009 4:14 pm
Right, so it is the filler neck that is the determining factor?
Has anyone fitted a Pajero tank to Soft Top Sierra? Successfully?
Post Posted: Thu Aug 13, 2009 5:18 pm
the size looks good, length and width. however for a SWB sierra, the height will end up comming up through the floor in the back a huge amount. you could maybe mount it sitting under the rails rather than ontop like pete did but i think you would find it sitting really low.
Vehicle: SJ80
Post Posted: Thu Aug 13, 2009 5:22 pm
So are you saying it would not be possible to fit in a Soft Top without a body lift?
Because mounting it on top of the chassis rails without a body lift would mean the top of the tank would come through the floor in the back?
Post Posted: Thu Aug 13, 2009 5:35 pm
Im not saying its impossible. :)
Im saying if you look at where pete has mounted his tank with the flange sitting ontop of the chassis rail by the looks of it. The tank hangs down to the bottom of the chassis rail. but sits up above the rail a good 8 to 10 inches. On a swb sierra the floor only sits above the chassis about the thickness of a rubber, ie 10-15mm. Therefore givving you about 8 inches of tank sitting up through the floor.
If you mounted the tank lower, so that the flange was level with the bottom of the chassis, you would have around 5 inches sitting below the chassis which wouldnt be a big deal as thats about what the standard one sits i believe. But you will still have around 2-3 inches sitting above the chassis rail, and so still sitting through the floor. with a body lift you might get it in.
Post Posted: Sat Aug 15, 2009 2:42 pm
I'll get some measurements above and below the seam for you.
