It is currently Tue Oct 20, 2026 9:44 pm
Post Posted: Tue Aug 25, 2009 10:28 pm
i took my coily down some dirt roads yesterday and now she just stalls when i come to a hol she was all fine and dandy before that. All the plugs seem to be in should i try adjusting the idle ?? any help would be greatful
Post Posted: Tue Aug 25, 2009 10:31 pm
there is a plug under the carbie with a hex head. Undo that and it will drain your carbes water choke, then re fill and check. My shorty gets stuck on sometimes and that has fixed it every time...lol
Post Posted: Tue Aug 25, 2009 10:33 pm
Let me guess...drives fine doesn't miss, just stalls when you try to idle!! I had the same problem...carbie. Luckily i had a spare. Try cleaning with a proper carbie cleaner, if not more terminal, carby shop or someone who knows more about them on here will be able to help.
Hope that helps you out.
Rusho
Post Posted: Tue Aug 25, 2009 10:34 pm
Learn something new everyday...thanks, did not know that
Post Posted: Tue Aug 25, 2009 10:37 pm
sweet thanks guys ill try them both..
yeh rusho exactly what your saying she drives sweet as then just stalls when i stop.. ill check it it
Post Posted: Tue Aug 25, 2009 10:42 pm
I'm getting about 350ish to a tank, but she's running a bit rough at the moment so could be better. Just saw this question on your post of your zook. 20 hrs....farkn keen mate!!!!
Check that a vacuum hose hasn't come off too (or split).
Post Posted: Tue Aug 25, 2009 11:02 pm
rusho im getting about 250 ha it just had a service too..yeh was a mission of a drive mate luckily for the ipod...
yeh i checked that want33s cheers
Post Posted: Tue Aug 25, 2009 11:44 pm
Maybe the carby is proply fuked!!
Post Posted: Wed Aug 26, 2009 12:30 am
idle solenoid, i had endless problems with mine. found a new one in a packet behind a shelf when i was helping suziworx move lol, fixed it up :)
Post Posted: Wed Aug 26, 2009 3:13 am
hopefully not rusho :/
ill look into it saam cheers...
funny thing is i just drove it now its alot cooler she runs 110% not a bother on her only seems to be stallling in the day when is hot ?
Post Posted: Wed Aug 26, 2009 9:32 pm
all good i just ajusted the idle and she is running sweet
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Sat Aug 29, 2009 3:27 am
this happned to my coily to. got my mate to rev it to 3 or 4 then blocked off the air intake so it would clean the jets then ran fine, adjusted the timing and now it runs like a beauty and uses heaps less fuel. i set my timing at 8.5 b t d c what does everyone else recommend?
1997 Sierra, daily driver, 60mm coils, 2 inch body
Users browsing this forum: Google [Bot] and 228 guests
