It is currently Tue Oct 20, 2026 9:44 pm
aka
aka
Post Posted: Sat Aug 29, 2009 10:02 pm
I have a typical sloppy steering box. I have tried a number of second hand units with no improvment. I have replaced the front bearings, tie rods etc and now the weakest link is the steering box.
Can any one sugest where I may be able to buy a new one or have my one reconditioned at a resonable price, close to the Gold Coast would be good.
Or is power steering an option in a 84 1Lt?
Experience is something you dont get until just af
Post Posted: Sat Aug 29, 2009 10:08 pm
some time ago the drama with rebuilding them was the shafts wore and couldnt be replaced, better steering shops can spray metal now to build them back up and machine back to new
Driveline Services are the people to see
aka
aka
Post Posted: Sat Aug 29, 2009 10:15 pm
Thanks Royce, I will drop them a line. Back in Charters it wasnt a worry but dealing with 3 lanes of Gold Coast traffic is a bit different!!
Vehicle: Nissan
Post Posted: Sat Aug 29, 2009 11:22 pm
i got a new steering box from suzi sport for my 91 1.3L for $400 i think
Pearce-toff Racing
Post Posted: Sun Aug 30, 2009 6:42 pm
there is a nut and screw on the top of the box loosen the nut then put the screw in a few turns then tighten the nut this should make it better be for i did it i could do half a turn before the wheels would move then done that and now it got a little bit of play hope it help i might try and get a pic if you need it
Post Posted: Sun Aug 30, 2009 8:22 pm
How tight should the screw be when you do that? Do you tighten until first contact, or do you keep tightening beyond that, if so how much more?
Post Posted: Sun Aug 30, 2009 8:36 pm
you need to screw it until its not noticeably loose or stiff when you turn the input, much easier to do in a vice with fresh oil
BUT for it to need adjusting something has worn which is where the play comes in anyway
Post Posted: Sun Aug 30, 2009 8:38 pm
mad Kenny adjusted his and the next day it failed completely.
Post Posted: Sun Aug 30, 2009 9:16 pm
Tighten till there is no play in steering. Easiest to do it with the front wheels off the ground. Once you have adjusted, spin steering from lock to lock and check for tight spots. If there are any, back off a little.
Post Posted: Sun Aug 30, 2009 10:53 pm
Sounds like Mad Kenny overtightened it, or maybe it was just a coincedence.
Post Posted: Sun Aug 30, 2009 11:09 pm
A truckie once said to me theres no point adjusting them cause they go sloppy cause bits wear, at the same time they wear the hardening off everything so when you adjust it it jsut loads up stuff that cant handle it anymore nad they fail
Post Posted: Sun Aug 30, 2009 11:25 pm
he is a boilermaker so that is probably what happened.
Post Posted: Sun Aug 30, 2009 11:27 pm
Ahhh yes, the boilermakers motto..... "As tight as you can and then another half a turn". !!
Post Posted: Mon Aug 31, 2009 12:15 am
ive got a spare steering box sittin here - no use for it... PM me with an offer if you want it
Post Posted: Mon Aug 31, 2009 12:43 am
Not with Kenny, there wouldn't have been a spanner in sight. More like a cold chisel and a big farking hammer.
Post Posted: Mon Aug 31, 2009 12:49 am
no crap he has a 20kg sledge hammer and can swing it no worries.
Post Posted: Mon Aug 31, 2009 1:03 am
the adjusting screw justs 'tightens' the feel, does not remove slop. adjust the input shaft bearings, just like on a diif side bearing.
Post Posted: Mon Aug 31, 2009 11:26 pm
iv often wondered how much play they had from factory?
cause every sierra iv driven has had play there.
but it still moves the pitman arm ever so slightly.
aka
aka
Post Posted: Mon Aug 31, 2009 11:55 pm
For your info I got a quote back from Driveline Services, $440 to rebuild my steering box, would take 2 to 3 days.
Users browsing this forum: Google [Bot] and 240 guests
