It is currently Sat Oct 24, 2026 4:20 pm
Post Posted: Tue Oct 27, 2009 9:58 pm
Hypothetically speaking, if my front diff housing is leaking around the right hand spring perch, can I just weld it up or is it best to buy a replacement housing? Could this is any way have anything to do with my wheel bearings failing every 6 months? i.e. would a crack in the perch weld and the fact it's leaking suggest that the housing itself could be bent? Or is it nothing to worry about?
(I haven't checked/replaced my bearings as per an earlier post but I only noticed this today and thought it may have something to do with it)
Cheers,
Jimmy.
Vehicle: MY2019 Jimny
Post Posted: Tue Oct 27, 2009 10:10 pm
Your bearings shouldn't be oily anyway, hence the axle seal.
Do you have a large offset or large tryes?
You should be able to just weld up the housing, but do it in small sections so as not to warp it too much.
Post Posted: Tue Oct 27, 2009 10:15 pm
The bearings aren't oily, the oil is coming out around the spring perch. I'll Weld it up in small sections like you said.
Post Posted: Tue Oct 27, 2009 10:26 pm
The only way you will be able to weld this up is if you strip the diff down and clean it properly. Diff oil is near impossible to weld through.
Post Posted: Wed Oct 28, 2009 4:38 am
you sure its leaking from your diff housing and not from higher up? my right hand springs had oil on them when i over filled the steering box :S
Users browsing this forum: No registered users and 118 guests
