It is currently Mon Oct 19, 2026 3:52 am
Vehicle: 97 SV420/627 SWB Vitara
Post Posted: Sat Nov 14, 2009 9:43 pm
Need ideas on how to hold the crank pulley stationary (J20A) while removing the retaining bolt. Ive been to my two local auto stores and neither have anything. Tried a chain style oil filter wrench and just bent the crap outta it. Any other suggestions?
Lifted, Locked & Loud. Expensive Little Toy...
Vehicle: MY2019 Jimny
Post Posted: Sat Nov 14, 2009 9:47 pm
Pull off a manifold, stuff some rag in the cylinder bore.
If it is in the car, can you just put it in gear and rattle gun it?
Is your car a manual Stuey? Is it your car?
Have you thort about h/brake on real hard & say, putting the g/bow in 4th?? :roll:
Post Posted: Sat Nov 14, 2009 9:50 pm
Yeah manual.. and yes its my car. So ur suggesting chuck it in 4th, reefing up the handbrake hard and trying that way? I take it slight backward rotation on the crank wont do damage its only major rotation.
Cant be farcked pulling off manifolds lump, but thanks for offering up a suggestion.
Post Posted: Sat Nov 14, 2009 9:58 pm
It's worked for me for over 2 decades.
No damage, it essentially what the eng dose anyway :roll:
Post Posted: Sat Nov 14, 2009 10:05 pm
Just how much force can i get away with here. I've just been outside and tried your suggestion but I'm litterally hanging off my spanner and it aint moving. Tried tapping it with a hammer. Next idea is a breaker bar for leverage but I'm just worried I can overdo the pressure and stuff something..
Post Posted: Sat Nov 14, 2009 10:08 pm
Spanner? 8O good luck!!!
Go the breaker bar & go hard!!!! When the bolt let's go you will hear a crack& unless you have broken the socket, it's loose.
Post Posted: Sat Nov 14, 2009 10:09 pm
you wont hurt anything
next step is breaker bar jammed against the chassis rail and bump the starter, never fails :)
Post Posted: Sat Nov 14, 2009 10:12 pm
Wanted to try it this way 1st, can fail, seen a socket explode.
Shit eh. Here I am worring cause I can see chains and stuff flexing under load and I can see the crank rotating backwards.
Post Posted: Sat Nov 14, 2009 10:13 pm
PULL STUEY , PULL!!!!!
Post Posted: Sat Nov 14, 2009 10:15 pm
yup.... just broke my socket. Lucky its lifetime warrenty. What a pig of a pulley
Post Posted: Sat Nov 14, 2009 10:21 pm
Tight hay!! 8O What brand of socket??
Post Posted: Sat Nov 14, 2009 10:44 pm
remember you gotta do it back up that tight too :)
Post Posted: Sat Nov 14, 2009 10:56 pm
As we call it FT, F*#king Tight !!! :P
Post Posted: Sat Nov 14, 2009 11:13 pm
Loctite FTW
Post Posted: Sun Nov 15, 2009 12:57 am
Got it. But what a mission. Big arse breaker bar, with my jack handle slid over that with me hanging on it. Farkin hell. Thanks for the input guys.
Post Posted: Sun Nov 15, 2009 1:11 am
What are you up to Stuey??
Was the gunk getting to you?? :P
Post Posted: Sun Nov 15, 2009 1:34 am
Yeah whats going on???? did ya pickup ya bracket from Brian yet??????????
Post Posted: Sun Nov 15, 2009 2:38 am
Yeah, sorta. But I'm not going as full on as head off stuff we were discussing before. I just wanted to pull off the timing chain cover, check the state of things behind there, clean that up a bit and possibly fit new timing chain kit if need be. As it turns out it was worthwhile as there was handfulls (litterally)of sludge behind there. Tomorrow I'll clean that up, I'll grab a new timing chain kit on monday. Then I'll commence reassembling. I've left the head alone. I still have your words "FLUSH IT" echoing around my head. :) But at least getting rid of the shit around this timing chain will be less for the flush to do. Makes sense to clean it off while the sump pan is off.
Post Posted: Sun Nov 15, 2009 2:42 am
So I made an impression on you then, Bet that's playing on ya.
You want to strip it & in the back of ye head a whore is saying "FLUSH IT" :rofl:
Stuey, I'll fly you over to Adelaide to clean my zook up any day...
Post Posted: Sun Nov 15, 2009 2:43 am
Yeah, I grabbed the bracket on Friday arvo. Only cost $25 for the powdercoating which was good. So now the push is on to have it all done for the Perth Auszookers meetup. I'll do a bit each night when I can. Diff wont take long to get back in (Ive had that out so many times now I could probably do it with my eyes shut). But I need to clean this engine sludge off first then reinstall the oil pan before putting the diff in. Then i can FINALLY see if your Calmini bracket works. Then radiator, belts, fan etc etc. Another one of those projects I wish I'd never started......
Post Posted: Sun Nov 15, 2009 2:45 am
What are you on about. Your princess is never dirty from what I can tell! :P
Post Posted: Sun Nov 15, 2009 2:46 am
Strangely enough... you've got that exactly right. :lol:
Post Posted: Sun Nov 15, 2009 2:53 am
Well you may as well keep on going now, you got the sump, timing cover & tappet cover's off, can't be much more hay?
I can't see you being happy till you do, but be prepared for a full rebuild as I'm sure you will find some thing else that is not to your liking in there. :roll:
:rambo: you go get that glug Stuey! :rofl: peaceout
Post Posted: Sun Nov 15, 2009 2:59 am
Shaddup.......ok so I'm a little fussy! :thefinger:
Fuck the rebuild..... if the thing blows up after this in goes that V6!
Post Posted: Sun Nov 15, 2009 3:01 am
That would be FUN to drive, steve is doing a 2lt v6 in a sierra, should be good.
Post Posted: Sun Nov 15, 2009 4:03 am
Just remember that bolt gets done up to the same torque :wink:
Post Posted: Sun Nov 15, 2009 12:11 pm
If only I had a dollar for every time i'd muttered that to myself in disgust... :lol:
Keep the faith Stuey, you'll get there mate!!!
Users browsing this forum: No registered users and 401 guests
