It is currently Thu Oct 22, 2026 6:22 pm
Post Posted: Thu Nov 19, 2009 11:00 am
i know this topic gets brought up alot but just wondering about the calmini 3" lift for the vit the rear end are the shockies lond travel or just a standard length like the front ones. cause the exchange rate is quite good at the moment and you can get it to your door for bout $1500.
Post Posted: Thu Nov 19, 2009 12:53 pm
The rear shocks are longer that stock ones.
The reason that the front shocks are standard length is to keep tteh CV's working within factory angles, once you start putting the CV's on big angles they fail much quicker.
Post Posted: Fri Nov 20, 2009 10:49 am
what about the ome struts are people know to break cv's with them in
cause i think that my suba has more travel out of it front than the vit
Post Posted: Fri Nov 20, 2009 1:01 pm
I am not sure if running the OME struts will make that difference.
mine seems to flex well enough
Post Posted: Fri Nov 20, 2009 1:58 pm
I'm running the Calmini kit with OME front struts, VT Commodore sedan rear shocks & I've never had a CV fail... yet!
It seems to flex alright with no sway bars?
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Fri Nov 20, 2009 9:48 pm
The Commodore Rear Shocks.... Are they off a Independant Rear (IRS) End Commodore or a Solid Diff Rear End Commodore??
The IRS Shocks are about 70mm longer than the Solid Rear Diff ones....
Did u have to extend your brake-lines (Rear) as well ??
I'm running the Solid Rear Diff Commodore Shocks ATM & if I want to run the IFS ones I've got to get longer Coils or do something to prevent the coils from falling out 8O
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Fri Nov 20, 2009 11:05 pm
Mine are ZIP tied so they stay in position. Seems to work
Vehicle: SJ51T
Post Posted: Fri Nov 20, 2009 11:55 pm
i do the same, works fine.
Post Posted: Sat Nov 21, 2009 12:54 am
rob
Banga, sorry about the thread hi jack...
Hey Rob,
The VT sedans are all IRS as far as I know, I really don't know squat about commonwhores apart catching a taxi...
I have extended rear brake line which are part of the calmini kit & relocated front lines.
To get this sort of flex ALL suspension components are replaced with the Calmini stuff, the springs would be twice the length of the stockers
Have a look thru this site.
http://www.puresuzuki.com/sidekick_tracker.htm
Post Posted: Tue Nov 24, 2009 10:37 am
yeah i have bin checkin it out at the moment. did you reckon they would sell it without the shocks and struts so i could get the ones i want just bought a new motor head gasket in the old one went. thats somethin are the auto's transfer the same ratio as the manual. as well got an auto vitara box sitting here if anyone keen not sure how much they are worth
Post Posted: Tue Nov 24, 2009 1:34 pm
They dont sell stuff seperately, it is a "kit".
There are some Chinese rip offs you can get seperately if you want to go that way.
I am sure ODA could get them.
Post Posted: Wed Nov 25, 2009 2:30 am
na ill just thought id see it would have bin nice to save a bit of cash and get the shocks and struts i wanted.
do you have a body lift in your vit rikstr
Post Posted: Wed Nov 25, 2009 7:58 pm
Yea it's got a 3" body lift in it
Users browsing this forum: Google [Bot] and 75 guests
