It is currently Thu Oct 22, 2026 2:56 pm
Post Posted: Wed Dec 02, 2009 12:24 am
hey guys got my g16a carb motor dummied up in a chassis and want to start it and check everything before i pull the 1ltr out of the maruti.
mainly need to know how to wire the coil and dizzy cheers
Vehicle: jimny
Post Posted: Wed Dec 02, 2009 1:00 am
just run a 12 positive to the coil +and an earth - to the battery and thats the coil sorted, as for the dizzy im sure someone will know that, coil hot wiring is the same for basically all carby cars
Post Posted: Wed Dec 02, 2009 1:27 am
12v pos to pos of coil.. nothing to neg of coil as the dizzy trigger's that.
12v pos to pos starter from a battery
neg of batt to the block
coil mount will need a neg or it will not fire
Post Posted: Wed Dec 02, 2009 1:57 am
thats how i tried to do it but i had the neg from dizzy to neg of coil but didnt have the coil earthed with a mount that explains the no spark hopefully itll run tomorrow cheers guys
Post Posted: Wed Dec 02, 2009 2:07 am
Sorry, I didn't realize you didn't have a harness.
pos of dizzy to pos of coil to :roll:
I assume to much. 8O
Post Posted: Thu Dec 03, 2009 12:22 am
ok had it all wired up
positive from battery to starter
negative from battery to block
positive from battery to positive of coil
positive from coil to brown wire on dizzy
negative from coil to black wire on dizzy
and coil earthed to block
still no spark !!!!!!
all i can think of is i have a dud dizzy maybe???
Post Posted: Thu Dec 03, 2009 12:31 am
Doubt it, coil may be.
Did you see it run before??
Do you have another coil you can try??
Where are you testing for spark? Is the rotor in?
Post Posted: Thu Dec 03, 2009 1:17 am
motor has just been rebuilt so havent seen it run yet :roll:
had a normal bosh coil set up from another car
then used a bosh gt coil that ive seen used on a mates zook last month
checking for spark on #1 lead with a plug out and earthed
rotor button is in and was not new but also swapped with another one
and timing was all set on the right markes at tdc
Post Posted: Thu Dec 03, 2009 1:32 am
I think you may not be getting a good enough earth on the coil body.
Just fit it all to the car, unless you have a harness you can loose to much in the contact's, only take one bad contact to not work.
If there are any problem's 99% of them can be sorted out in the car, eg vacc leak's or the such.
Post Posted: Thu Dec 03, 2009 2:08 am
i just wanted to make sure its all good before i put it in my daily driver becuase if i fit it and it doesnt go public transport isnt in my area and with it being a 1ltr once the mounts are cut off theres no turning back
i do have a second wire harness but that is still fitted to another shell ill have another crack at it tomorrow cheers for your help steknig i appreciate it
Post Posted: Thu Dec 03, 2009 2:11 am
That's the go!!
Users browsing this forum: Google [Bot] and 154 guests
