It is currently Sun Oct 25, 2026 6:47 am
Post Posted: Thu Dec 31, 2009 5:22 pm
Is there a alternate to the rag joint. ie unijoint. if so which model do I get one from and does it bolt straight in .
Mine is a 85 drover lwb with a bl.
98 GV
Post Posted: Thu Dec 31, 2009 5:32 pm
You need to get a spacer off Just Cruizin :wink:
Post Posted: Thu Dec 31, 2009 6:33 pm
What about the joint? any alternate
98 GV
Post Posted: Thu Dec 31, 2009 7:07 pm
There is no uni joint replacement for the rag joint.. Nothing that will bolt straight in anyway.
The original rag joint is a piece of crossply tyre but JC's replacements are poly or double thickness poly for BL's.
The idea of the rag joint is to act like a uni but to tear in the event of a major collision so the steering column doesnt shishkebab you.
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Dec 31, 2009 7:25 pm
http://www.lowrangeoffroad.com/samsteering.htm
there's a rag joint eliminator on that page, but as want33s said good idea to keep it in the system for safety reasons. There's also a rag jiint replacement on the same page.
Post Posted: Fri Jan 01, 2010 12:21 am
Do coilys have a rag joint or unit joint, i have alot of play in what i think is a uni joint, the first joint as the colum comes through the firewall?
Post Posted: Fri Jan 01, 2010 12:25 am
bigrig the play will be in your steering box.
Post Posted: Fri Jan 01, 2010 1:24 am
That's been adjusted.. :roll:
Same time as the tappet's.
Post Posted: Fri Jan 01, 2010 2:03 pm
Ok thanks for the info :) will stick with the rag joint for now ( see if i can find one local) then look into Jc's spacer. Got some work to do on my ute spring too rigid shackles are straight up bl is dodgy, hmmm maybe wt diffs and ruf at the same time..
Thanks again for the info
May the new year bring lots of :D :cheers: :woohoo:
98 GV
Users browsing this forum: No registered users and 165 guests
