It is currently Sat Oct 24, 2026 11:13 am
Post Posted: Wed Jan 27, 2010 4:02 pm
OK, for all you people who love the coily Sierra's and Jimny's :D
I would like to know the length of a short side coily rear axle shaft, and/or the length of the short side Jimny rear axle shaft. Measurement from the end of the spline to the surface that the drum bolts onto would be lovely :D
Thanks
Clearance Hole Technology :P
Post Posted: Wed Jan 27, 2010 6:11 pm
Dunno about Jimny but coily axles are 15mm longer each side than WT axles.
That trivia may help. :roll: :wink:
Post Posted: Wed Jan 27, 2010 6:27 pm
Hey Thanks.
If then the short shaft is also 15mm longer than WT, it might be what I am after :D
Post Posted: Thu Jan 28, 2010 3:13 am
Could be wrong, but I thought it was 17.5mm per side.
Post Posted: Thu Jan 28, 2010 3:16 am
Yeah ok.... 15mm plus a cutting disc.... 8O
Post Posted: Thu Jan 28, 2010 3:26 am
Either or should be OK.
Need a Suzuki 26 spline shaft that is ~548mm long. WT short side is ~538mm long. So hopefully a coily shaft will work, even if it requires some trimming :D (pending the spline being long enough).
Now I just need to find some, this might be the hard part :? :lol:
Thanks Guys :D
Vehicle: SJ80
Post Posted: Thu Jan 28, 2010 3:31 am
There is a dead coily at Ipswich auto wreckers at Brassal. Last time I was there (about 2 weeks ago) the drivetrain was complete.
Post Posted: Thu Jan 28, 2010 3:35 am
really? My old man said the entire rear diff was gone :?
Might give them a call tomorrow, I am a regular customer there :P
Vehicle: SJ80
Post Posted: Thu Jan 28, 2010 3:40 am
yeah, might be an idea to call them :? I'm sure it was complete, I was under it looking for a speedo cable.
Post Posted: Thu Jan 28, 2010 3:49 am
I am running a trimmed coily axle in a WT diff.
I trimmed about 15mm off. Heaps of spline left ;)
Post Posted: Thu Jan 28, 2010 3:54 am
Sweet, thanks Taff. They will definitely be what is wanted then, just need to get them.
Yeah, I'll call them bagnkat. My father does get a bit confused at times, anyway hes usually paying more attention to the Toyota wrecks.
Post Posted: Fri Jan 29, 2010 1:38 am
now just need another one :)
Post Posted: Fri Jan 29, 2010 3:49 am
Yeah, thanks bagnkat, got the shaft from that coily today. The rear diff was there, just not attached to the car lol.
a second one, and we'll be all set :D
Post Posted: Fri Jan 29, 2010 4:50 am
did you see any rear control arms for that coily?
Post Posted: Fri Jan 29, 2010 5:11 am
Yeah, the drivers side rear one was there, attached to the chassis. Not sure about any of the others.
Post Posted: Sat Jan 30, 2010 3:20 am
Jimny's short rear axle are 565mm long with 45mm of spline
Post Posted: Sat Jan 30, 2010 5:01 am
Cheers, that clears up that unknown then. Probably could just get away with a heavily trimmed down one, but I think the coily is the go. When we figure out the final few teething issues I'll post up what I'm getting at... I think its pretty cool anyway :D
Users browsing this forum: Google [Bot] and 177 guests
