It is currently Fri Jul 17, 2026 6:48 pm
Post Posted: Wed Apr 04, 2012 4:29 pm
Hi guys,
I know that Stockman's never come with a tacho but some of the earlier models (around 86 i believe) had a tacho guage in the same looking cluster which is a direct bolt in and plugs to the original harnes
Looking for a "Stockman cluster" with a tacho
If anyone has one in good nick, please let me know
Im located in Perth
Post Posted: Wed Apr 04, 2012 8:47 pm
Mate i carnt see the pics for some reason but i have a tacho cluster from a later N/t witch might be what your after.
Post Posted: Wed Apr 04, 2012 9:47 pm
Don't confuse the issue by asking for a stockman cluster with a tacho, for a maruti.
A stockman is an LJ.
You need a 1.3L NT sierra cluster. It will have the same dash as your maruti, only it has the clock in the centre of the dash between the vents, where yours has a blank.
Post Posted: Thu Apr 05, 2012 8:19 am
Hi All,
MasterA, the photo of the instruments second from top with the tacho is a 1.3L NT one. Have just sold one on ebay for $41.00 and there are more in my shed, sending it over to your fine State is not a problem either. So if you want, you can have one for $41.00 plus postage, post here or PM me your details.
Regards
Greg
COOL BANANAS!
Post Posted: Thu Apr 05, 2012 9:54 am
Thanks for clarifying....learn something new every day
Is there a reason why the Maruti's (even th late model ones) came with Stockman decals on them?
Boggomobile wrote:
Hi All,
Regards
Greg
PM sent :)
Post Posted: Thu Apr 05, 2012 8:30 pm
Dealership gimmick? My WT maruti had the same stickers... But the purists will tell you that the stockman was infact an LJ. :wink:
Post Posted: Thu Apr 05, 2012 10:21 pm
PM sent :)
The instruments without Tacho were in JA spec vehicles (which was the Type 3 1.0lt, Maruti NT and WT, and some NT 1.3). The Tacho came in JX trim in the NT 1.3, which also included a dashboard clock, intermittent wipers and split-fold rear seats. While they are a bolt swap, are you sure the wiring plug is the same? Workshop manual shows same plug, but with different circuits in different places.
Post Posted: Fri Apr 06, 2012 1:30 am
I read somewhere on here that it's a direct swap....plug and play (so to speak)
There are 2 plugs on the cluster along with the speedo cable....(i'll try finding the link)
Vehicle: '94 suzuki maruti
Post Posted: Fri Apr 06, 2012 7:08 am
i've also read straight swap... but be sure to let us know, i want a tacho, but want it looking stock
Post Posted: Fri Apr 06, 2012 4:02 pm
Found it
viewtopic.php?f=5&t=13574
I would like to keep my original also....don't like the idea of fitting 5" monster tacho's on the dash or drilling holes and those 2" ones that fit int he holes are all digital which i don't like
Thanks for the replies....think i may have found one :)
Post Posted: Wed Jun 13, 2012 4:48 pm
Just a quick upate on this for all that were interested....it's actually a direct swap (plug and play)
If you had an engine conversion and you did abit of cutting, remember to hook up the brown wire (with pink dots on it) to the negative of the coil ;)
Vehicle: 85.Ruf. rear air locker
Post Posted: Wed Jun 13, 2012 6:13 pm
when i put mine in it was plug and play
Post Posted: Thu Jun 14, 2012 7:35 am
sweet. cheers for letting us know, im sick of not having a tacho :)
Post Posted: Sat Jun 16, 2012 8:30 am
got a tacho with dash if needed. Brisbane. inbox me
Users browsing this forum: No registered users and 30 guests
