| Author |
Message |
DAMMIT
Joined: Sun Jun 03, 2012 9:12 pm Posts: 7 Location: Darwin, NT
Vehicle: 91 sierra s/t, g16b, 31's, etc
 Posted: Sun Jun 03, 2012 9:45 pm |
Chasing bits to get my baby back out there.
Had sludge release in the rocker rail, block three journals and five rockers. It's just eaten itself!!
In need of replacement port injection head and vitara cam.
Appreciate help from anyone with those bits/motor.
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Mon Jun 04, 2012 7:36 am |
Where are you locate mate
JrZook
 Posted: Mon Jun 04, 2012 1:00 pm |
^^x2 If you are in briz I may know of a G16 head and cam
_________________ Lil Foot!
ramjet
Joined: Sat Jun 05, 2010 8:45 am Posts: 128 Location: Brisbane
 Posted: Mon Jun 04, 2012 4:23 pm |
JrZook wrote: ^^x2 If you are in briz I may know of a G16 head and cam I am the person JrZook knows that has a spare G16 head (untested), Also have a G16A motor sitting here which works. So if your in bris let me know.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jun 05, 2012 2:00 pm |
G16BA?????
It is either a G16A or G16B
Can't be both. Is it 8 valve carby or 16 valve EFI?
2stroker
 Posted: Tue Jun 05, 2012 3:10 pm |
He says its a port injection head so still could be either an A or a B but obviously 16 valve
DAMMIT
 Posted: Tue Jun 19, 2012 11:07 am |
Sorry guys, got sent to Groote Eylande for two weeks. Donk is G16BA, 94 Vitara multi port injection. I'm not worried were you guys are, I'll freight it no problem. I'll try making my profile photo of it
Fatzook
 Posted: Tue Jun 19, 2012 11:14 am |
DAMMIT wrote: Sor Donk is G16BA, 94 Vitara multi port injection.
No such thing as a G16BA mate. Only G16A or G16B. Either way, you need a 16v head.
DAMMIT
 Posted: Tue Jun 19, 2012 5:47 pm |
Block is stamped G16BA, have another 16v head but it's not port injection, mate.
2stroker
 Posted: Tue Jun 19, 2012 6:40 pm |
I have seen acouple of those blocks and have one of those blocks at the moment, it has G16A on the bellhousing face and G16B on the engine number.
Sorry mate head is gone.
DAMMIT
 Posted: Wed Jun 20, 2012 9:55 pm |
Was just chatting with a bloke who has seen this motor before, he went on to explain about the three different aussie importers & how WA seemed to get an American type of version. As in, when the rest of Oz got a carby suzuki, WA got the same car in efi. Now I don't know if that's what's going on here, but the donor car was WA rego'd, and when I was extracting the ecu and wiring it had an emission control system the wiring diagram states as only on californian vehicles. So, the question is, do the mid 90's 16v efi heads have the same relief at the top of the port for the injectors, as previous post say I only need a 16v head & I have another 16v G16B motor & the blocks look identical but the head does not have the injector reliefs.
DAMMIT
 Posted: Thu Jun 21, 2012 6:06 am |
Ports in question.
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Thu Jun 21, 2012 8:37 am |
That kinda looks like mine. Which is a G16b. I've gotta pull out the engine in my Vit so I'll have the head available shortly and I have a cam ready to go now. Where are you located? this is one I just had rebuilt, so it's not for sale.
DAMMIT
 Posted: Thu Jun 21, 2012 11:05 am |
Hell yes! That's the bastard there! The casting imprints at the top are a bit different, mine doesn't have numbers or characters either, but close enough! I'm up in Darwin, so you get used to paying the postage on everything. Let me know what you want for them, but I'm back out bush again on Tuesday for two weeks, cheers, Rob.
buzbox
 Posted: Thu Jun 21, 2012 11:13 am |
Well, at this stage it won't be until 1-2 weeks until I get this motor ripped out.
The head pictured is from a 94-98 G16b Vitara, Mine is an early model, but I'm sure they'd be the same. Unless someone else here knows off the top of their noggin, I'll confirm it once I remove it.
I do have the '94-98 cam which is ready to be sent. I'll be using the cam that's in my current engine in the head pictured.
JrZook
 Posted: Thu Jun 21, 2012 12:36 pm |
That head is just a 16V MPFI head which is pretty common. Only some early 1600 swifts and imports have no injector reliefs because they were running a throttle body injection unit.
DAMMIT
 Posted: Thu Jun 21, 2012 4:23 pm |
Yep that would be it, the ones I can find here are throttle body with no reliefs, still marked as g16b. Old mates photo, other than numbers & patterns, looks identicle at the ports. Thanks guys, finally confirmed as a g16b MPFI
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Thu Jun 21, 2012 5:19 pm |
there are stacks of throttle body injected vitaras in the nt. i had 2 for work cars, both were 94 4 door jobbies.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Booyar
Joined: Thu Jul 29, 2010 12:55 am Posts: 14 Location: Wagga NSW
 Posted: Tue Jul 03, 2012 7:05 pm |
