| Author |
Message |
Chapster
Joined: Mon Feb 21, 2011 10:50 am Posts: 103 Location: Sydney
 Posted: Wed Mar 23, 2011 3:03 am |
Seeing that i stuffed mine....
The local wreckers don't have one
its going on a 96 HT EFI 16 valve SWB vitara
Chapster
 Posted: Wed Apr 06, 2011 8:16 pm |
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Wed Apr 06, 2011 8:18 pm |
suzifour dunheved?
suzukisubarumini seven hills?
Chapster
 Posted: Thu Apr 07, 2011 9:27 am |
Thanks dude suzifour only had lwb ones
Seven hills has a swb one but it's for a 2L when mines a 1.6l
I'm going there tomorrow to compare the size difference
My question is there?
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Thu Apr 07, 2011 9:57 am |
Chapster wrote: Thanks dude suzifour only had lwb ones
Yep. Substantial size difference. Infact I would be suprised if the 2.0L tank would even fit between your chassis rails. The 2.0L has a wider chassis.
_________________ 2013 GV 1998 SV420 ute
BlueSuzy
 Posted: Thu Apr 07, 2011 1:12 pm |
The mountings will probably be different.
This is the 1.6 swb vit efi tank dimensions
Chapster
 Posted: Thu Apr 07, 2011 2:36 pm |
Jez it's becoming a mission to get one I've emailed and rang around a lot of wreckers. Even went to two radatior places who knocked me back
One said he could fix the hole but couldn't straighten the tank out because off how flat I made it
In This solution you guys are entitled to call me a Dickhead
BlueSuzy
 Posted: Thu Apr 07, 2011 11:02 pm |
Why are you a dickhead if your blind and can't find one?
I have a coily sierra one here you can use for the moment..
Doesnt leak but is pretty dented. Efi compatible. Just bolt in your pump. But completely different mounts.
I know there is a swb carb vit tank in Pick and Payless, But they puncture all tanks to empty them for insurance reasons..
I can't be more of a help
lux65
Joined: Wed May 26, 2010 12:11 pm Posts: 36 Location: Halfway between Newy & the Bay
Vehicle: LWB zook (sold), lux, Disco II
 Posted: Fri Apr 08, 2011 11:09 am |
got a tank in the shed not sure whether it came from swb, will check it on sunday.
Chapster
 Posted: Fri Apr 08, 2011 11:58 am |
The guys at seven hills told me you might be able to fit a the 5 door tank can that be done?
Went to pick n payless today they had a 95 5 door which I managed to get the infamous cup holder center out of it. Cost me $10 with brackets
Chapster
 Posted: Mon Apr 18, 2011 5:49 am |
Chapster
 Posted: Sat Apr 23, 2011 7:46 am |
Bump
