It is currently Wed Jul 15, 2026 4:27 am
Post Posted: Wed Mar 23, 2011 3:03 am
Seeing that i stuffed mine....
The local wreckers don't have one
its going on a 96 HT EFI 16 valve SWB vitara
Post Posted: Wed Apr 06, 2011 8:16 pm
TTT
Post Posted: Wed Apr 06, 2011 8:18 pm
suzifour dunheved?
suzukisubarumini seven hills?
Post Posted: Thu Apr 07, 2011 9:27 am
Thanks dude suzifour only had lwb ones
Seven hills has a swb one but it's for a 2L when mines a 1.6l
I'm going there tomorrow to compare the size difference
My question is there?
Post Posted: Thu Apr 07, 2011 9:57 am
Yep. Substantial size difference. Infact I would be suprised if the 2.0L tank would even fit between your chassis rails. The 2.0L has a wider chassis. :(
Post Posted: Thu Apr 07, 2011 1:12 pm
The mountings will probably be different.
This is the 1.6 swb vit efi tank dimensions
Post Posted: Thu Apr 07, 2011 2:36 pm
Jez it's becoming a mission to get one I've emailed and rang around a lot of wreckers. Even went to two radatior places who knocked me back
One said he could fix the hole but couldn't straighten the tank out because off how flat I made it
In This solution you guys are entitled to call me a Dickhead :)
Post Posted: Thu Apr 07, 2011 11:02 pm
Why are you a dickhead if your blind and can't find one? :D
I have a coily sierra one here you can use for the moment.. :lol:
Doesnt leak but is pretty dented. Efi compatible. Just bolt in your pump. But completely different mounts.
I know there is a swb carb vit tank in Pick and Payless, But they puncture all tanks to empty them for insurance reasons..
I can't be more of a help :(
Vehicle: LWB zook (sold), lux, Disco II
Post Posted: Fri Apr 08, 2011 11:09 am
got a tank in the shed not sure whether it came from swb, will check it on sunday.
Post Posted: Fri Apr 08, 2011 11:58 am
The guys at seven hills told me you might be able to fit a the 5 door tank can that be done?
Went to pick n payless today they had a 95 5 door which I managed to get the infamous cup holder center out of it. Cost me $10 with brackets
Post Posted: Mon Apr 18, 2011 5:49 am
Bump
Post Posted: Sat Apr 23, 2011 7:46 am
Bump :(
