It is currently Sat Jul 18, 2026 7:19 pm
Vehicle: '95 lwb vitara
Post Posted: Mon Nov 07, 2011 7:54 am
As above, front diff went farkin' BANG up on the Old Coach road last weekend before the infamous 'steps'. Managed catch it on footage and did the rest in 2wdL. ;)
I've heard that a GV steel housing mounts up the same but the internals need modification?
What needs to be done for this too work?
Any info helps fellas. :)
Cheers.
Post Posted: Mon Nov 07, 2011 8:04 am
yes.
Vehicle: Suzuki
Post Posted: Mon Nov 07, 2011 8:49 am
So what were you doing to make it go bang?
Post Posted: Mon Nov 07, 2011 9:06 am
I put new 235/75 muddies on her, and I was crawling up a fair ledge, rocky surface she slipped sideways, I slipped on the go-go pedal she bounced up coming down and too much force went through the diff, BANG. Curses were said, but didn't stop me from completing the track.
Atari; What do you mean yes? Yes, to it can be done and it mounts up the same, or?
Cheers.
Post Posted: Mon Nov 07, 2011 9:08 am
sorry i'm posting from my phone, yeah it can be done & it bolts up... there are a few threads regarding the steel diff swaps, have a search for "GV steel"
Post Posted: Mon Nov 07, 2011 9:19 am
Thanks mate. :)
Post Posted: Tue Nov 08, 2011 9:41 am
Can't find the info I need.. I know I need the GV front housing, but i'm not sure what year or model Grand Vitara housing i need, OR what internals I use?..
Help would be great. :)
Post Posted: Tue Nov 08, 2011 11:01 pm
Housings are the same just one is steel the other is alloy. Internal are interchangeable with a Vit. GV ratios are different so you just have to put your vit center into it. GV's have 26 spline axles.
Post Posted: Wed Nov 09, 2011 9:37 am
Alright sweet. So there is no modification that needs to be done to the housing to fit the standard Vit internals?
Awesome. :) Cheers man.
Post Posted: Wed Nov 09, 2011 9:44 am
really? :?
you still running the calmini kit in your Vitara?
http://auszookers.com/index.php?name=Fo ... steel+diff
Post Posted: Wed Nov 09, 2011 10:23 am
Yeah mate still running the Calmini kit.
Cheers.
Post Posted: Wed Nov 09, 2011 10:25 am
unless you want to fabricate a new pinion mount, you'll need the early GV steel diff from a 98-99 manual GV 2.5 SQ625. one of those links will have pics of the 2 different types of pinion mounts.
if your diff survived the explosion you need to have them swapped into the GV 3rd member
Post Posted: Thu Nov 10, 2011 2:16 am
ATARI.. Apologising?? I never thought I'd see the day! 8O :lol:
Post Posted: Thu Nov 10, 2011 2:47 am
Get fuckt :thefinger:
Posted from my iPhone!
Post Posted: Mon Nov 14, 2011 5:22 am
Is this the vid? :P
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Nov 14, 2011 5:37 am
chop has as GV steel diff already set up with 5.12's.
i doubt you'd be able to find one + a new R&P and have the diff gears swapped over for less than what he wants for it.
Post Posted: Mon Nov 14, 2011 5:50 am
the housings are the same but the axles and centers are different. you can fit the vit center into the GV housing butthe vit stuff is alloy. best to get a steel diff and center from an early V6 GV.
Post Posted: Fri Nov 18, 2011 8:22 am
Yep that's the vid! :D
So if I were to install the GV c&p and housing into my Vit, i'd have to change the rear diff ratio yeah?
Cheers Atari, will ask him..
Post Posted: Fri Nov 18, 2011 8:31 am
yes, but why would you want to do that? :?
Post Posted: Fri Nov 18, 2011 12:11 pm
Coz GV's are even more Awsome that vitaras
Post Posted: Fri Nov 18, 2011 11:15 pm
I doubt that very much ^^^^ I'll hit chop up and see what he's asking for it.
