It is currently Sat Jul 18, 2026 11:20 am
Post Posted: Fri Jan 06, 2012 10:48 am
after a cheap jimny transfer case in working order
Post Posted: Fri Jan 06, 2012 7:00 pm
Electric or manual???
Post Posted: Fri Jan 06, 2012 8:30 pm
manual
Post Posted: Fri Jan 06, 2012 8:31 pm
its for a 2001 model if that makes any differance
Post Posted: Fri Jan 06, 2012 10:56 pm
manual
Post Posted: Sun Jan 08, 2012 2:14 am
anybody?
Post Posted: Sun Jan 08, 2012 4:00 am
Are you replacing a working one or a dead one?
Post Posted: Sun Jan 08, 2012 7:36 pm
I need the complete transfer I haven't got one
Post Posted: Mon Jan 09, 2012 12:58 am
What are they worth from the wreckers I dont really Want to spend much I want one to pull apart I was thinking about modding one with a extra gear with a dog engagement setup for crawling so I can have the normal high range then the stock low range aswell as a solenoid operated setup that dogs a gearset into ultra low might even machine a entire transfer case up from billet aluminum Just need one to pull apart to play around with
Post Posted: Tue Jan 10, 2012 4:27 am
Post Posted: Tue Jan 10, 2012 4:36 am
will also buy a broken transfer
Post Posted: Thu Jan 12, 2012 10:11 am
anybody need this asap
Post Posted: Thu Jan 12, 2012 12:00 pm
Why not just put a sierra t-case in if your looking for lower gearing? :helloo:
Post Posted: Thu Jan 12, 2012 5:35 pm
i drive the car on the highway every day so i want the stock ratio and a crawling gear i already have a billet of aluminium to make a complete transfer if i cant mod the stock one how i want
Post Posted: Thu Jan 12, 2012 7:11 pm
Jonno_racing might sell you his once he arrives back to tassie next month, im sure he will be looking to upgrade, where are you located in tas?
Post Posted: Thu Jan 12, 2012 10:07 pm
Hobart
Post Posted: Fri Jan 13, 2012 7:28 am
What size tyre's do you have on it?
Post Posted: Fri Jan 13, 2012 10:58 pm
31"
Post Posted: Fri Jan 13, 2012 11:06 pm
Just put a sierra t-case in, it will bring your cars raitos back to stock....
Post Posted: Sat Jan 14, 2012 4:48 am
Don't want to stuff around with thd mounts etc
Post Posted: Sat Jan 14, 2012 8:57 am
ok been doing some research and i dont think the chain will be strong enough what sierra box do i need im running 31'' tyres and would like to have it back to stock ratio then make my own 2 speed box and put it between the gearbox and transfer box one gear being strait through and the other extremely low also with a sierra box what will happen with the speedo drive is this any good to me http://www.ebay.com.au/itm/Suzuki-Sierr ... 1c22b9d04f
Post Posted: Sun Jan 15, 2012 6:01 am
Just buy a the "off road armoury" conversion kit :helloo:
You will need x2 wide track sierra front drive shaft's and a WT jack shaft to...
Users browsing this forum: No registered users and 24 guests
