| Author |
Message |
2.7turbojimny
Joined: Thu Jan 05, 2012 4:25 am Posts: 38 Location: tasmania
 Posted: Fri Jan 06, 2012 10:48 am |
after a cheap jimny transfer case in working order
steak_knife
 Posted: Fri Jan 06, 2012 7:00 pm |
Electric or manual???
2.7turbojimny
 Posted: Fri Jan 06, 2012 8:30 pm |
2.7turbojimny
 Posted: Fri Jan 06, 2012 8:31 pm |
its for a 2001 model if that makes any differance
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Fri Jan 06, 2012 10:56 pm |
manual
2.7turbojimny
 Posted: Sun Jan 08, 2012 2:14 am |
Bugsta
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
 Posted: Sun Jan 08, 2012 4:00 am |
Are you replacing a working one or a dead one?
_________________ If you can read this, please tip me back over
2.7turbojimny
 Posted: Sun Jan 08, 2012 7:36 pm |
I need the complete transfer I haven't got one
2.7turbojimny
 Posted: Mon Jan 09, 2012 12:58 am |
What are they worth from the wreckers I dont really Want to spend much I want one to pull apart I was thinking about modding one with a extra gear with a dog engagement setup for crawling so I can have the normal high range then the stock low range aswell as a solenoid operated setup that dogs a gearset into ultra low might even machine a entire transfer case up from billet aluminum Just need one to pull apart to play around with
2.7turbojimny
 Posted: Tue Jan 10, 2012 4:27 am |
2.7turbojimny
 Posted: Tue Jan 10, 2012 4:36 am |
will also buy a broken transfer
2.7turbojimny
 Posted: Thu Jan 12, 2012 10:11 am |
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Thu Jan 12, 2012 12:00 pm |
Why not just put a sierra t-case in if your looking for lower gearing?
_________________ Tell my arse, he actually gives a crap!
2.7turbojimny
 Posted: Thu Jan 12, 2012 5:35 pm |
i drive the car on the highway every day so i want the stock ratio and a crawling gear i already have a billet of aluminium to make a complete transfer if i cant mod the stock one how i want
Brenno
Joined: Thu Apr 22, 2010 11:30 pm Posts: 996 Location: Hobart
 Posted: Thu Jan 12, 2012 7:11 pm |
Jonno_racing might sell you his once he arrives back to tassie next month, im sure he will be looking to upgrade, where are you located in tas?
2.7turbojimny
 Posted: Thu Jan 12, 2012 10:07 pm |
monley
 Posted: Fri Jan 13, 2012 7:28 am |
What size tyre's do you have on it?
2.7turbojimny
 Posted: Fri Jan 13, 2012 10:58 pm |
monley
 Posted: Fri Jan 13, 2012 11:06 pm |
Just put a sierra t-case in, it will bring your cars raitos back to stock....
2.7turbojimny
 Posted: Sat Jan 14, 2012 4:48 am |
Don't want to stuff around with thd mounts etc
2.7turbojimny
 Posted: Sat Jan 14, 2012 8:57 am |
ok been doing some research and i dont think the chain will be strong enough what sierra box do i need im running 31'' tyres and would like to have it back to stock ratio then make my own 2 speed box and put it between the gearbox and transfer box one gear being strait through and the other extremely low also with a sierra box what will happen with the speedo drive is this any good to me http://www.ebay.com.au/itm/Suzuki-Sierr ... 1c22b9d04f
monley
 Posted: Sun Jan 15, 2012 6:01 am |
2.7turbojimny wrote: ok been doing some research and i dont think the chain will be strong enough what sierra box do i need im running 31'' tyres and would like to have it back to stock ratio then make my own 2 speed box and put it between the gearbox and transfer box one gear being strait through and the other extremely low also with a sierra box what will happen with the speedo drive is this any good to me http://www.ebay.com.au/itm/Suzuki-Sierr ... 1c22b9d04f
Just buy a the "off road armoury" conversion kit
You will need x2 wide track sierra front drive shaft's and a WT jack shaft to...
