It is currently Mon Jul 13, 2026 3:12 pm
Post Posted: Fri May 16, 2014 9:04 pm
hi im after a crownwheel from a 4.3 centre they have a 43 tooth count also after a rh inner cv to make a stubby shaft. Thanks in advance for any replys
Post Posted: Fri May 16, 2014 10:31 pm
front or rear?
Why only the crownwheel, and not the matched set (ring and pinion)
Post Posted: Fri May 16, 2014 10:37 pm
Crap sorry rear wanting to try a mixture of gears hoping to run a 43 tooth cw with an 8 tooth pinion for 5.375 gears. Ive already got the front
Post Posted: Sat May 17, 2014 8:06 am
good luck with that.
Post Posted: Sat May 17, 2014 8:08 am
Yeah... That's not going to work.
Post Posted: Sat May 17, 2014 8:25 am
Ive got a 5.1cw and 4.3 pinion in a carrier right now with no binding wws kinda hoping it would work the other way .will put it together when I put my steel diff in and check tooth pattern etc
Post Posted: Sat May 17, 2014 8:34 am
If it doesn't bind straight away then you have lucked out and the pressure angles are similar enough to not feel it. I think you will still have problems with the pressure angle under power.
Gears are paired though, you shouldn't use a second hand gear from two different sets. It will cause premature wear and strength issues.
Post Posted: Sat May 17, 2014 8:46 am
Yeah I know that but was just kinda hopeful it might work .... rh inner cv cup anyone??
Post Posted: Sat May 17, 2014 8:55 am
Just don't try it too far from home :lol: do you want a gv or sv rh inner cup?
Post Posted: Sat May 17, 2014 9:18 am
Gv i think arent they the higher spline count 26 i think. Imfigure if im going to the effort of putting the steel diff in and making a stubby shaft i might as well upgrade to the larger axle/spline count while im at it
Post Posted: Sun May 18, 2014 6:53 pm
got heaps of GV ones but they wont clip into the Vitara centre. You want the 26 spline inner for a 95-97 SV420 / SV620 Vitara.
Post Posted: Sun May 18, 2014 7:21 pm
If there was a 1530 lockright with the 26 spline couplers going in at the same time would this make a difference??
Post Posted: Mon May 19, 2014 1:57 pm
Ok scratch crownwheel just after cv.... Anyone?
Post Posted: Tue May 20, 2014 9:36 pm
Nothing??
Users browsing this forum: No registered users and 26 guests
