It is currently Sat Jul 18, 2026 11:37 am
Vehicle: 98 Sierra Soft Top
Post Posted: Wed Feb 20, 2019 12:20 am
Hi all; I am wondering if anyone would have a rear diff centre for an SJ80 Sierra, 1998 model, that you might be inclined to sell. I have manged to break a bunch of teeth off my crown wheel and pinion. Thanks in advance for any help or suggestions that anyone may have for me. Regards Rod.
Vehicle: Coily.
Post Posted: Wed Feb 20, 2019 8:47 am
Very hard to find Rod,just out of interest where are you located?.
Regards All from far Northern NSW.
Post Posted: Wed Feb 20, 2019 5:03 pm
hey mate, hows things? Yeah, I am finding that statement to be accurate. found one but it needs the spindles changed as there are a different number of splines for the axles. I'm west of Ipswich in qld.
Vehicle: Coily.
Post Posted: Wed Feb 20, 2019 7:50 pm
Hi Rod,i have a Coily diff that needs a new Pinion,if that's any help i'll try and find it on the W/end and post a Pic.I'm down Lismore way.
The other option is to contact one of the Jap. Spares importers in Sydney or Brisbane,only problem is the Coily is getting old now but you may be lucky.
Vehicle: sc100 se416 mightyboy
Post Posted: Wed Feb 20, 2019 10:36 pm
I might get confirmation from someone that knows, but the REAR(only)from SJ80 should have the same ring pinion and ratio to the sj50..
Why make your Suzuki like a Vitara, Just get one.
Post Posted: Thu Feb 21, 2019 12:03 am
Sj80 have the same differential as 3.9 ratio sj50 1985 to 88
Post Posted: Thu Feb 21, 2019 10:32 am
An SJ80 doesn’t have rear spindles as the axle is semi floating and the axle splines are the same as every other Sierra rear- 26 spline. All factory Sierra front axles are 22 spline regardless of model.
As has been pointed out, ratio is 3.9, same as NT 1.3 Sierra.
The sj80 cast housing is different as it has a bracket for a vibration damper. This isn’t relevant if you only need gears. If you swap the whole third member in from a 1.3 NT, you’ll need to use 1/2 of a 1.3 tailshaft, swap the yoke on the tailshaft diff end to suit the 1.3 NT, or swap the sj80 pinion flange onto the NT pinion, which will require a new crush sleeve and care when setting up to achieve the correct bearing preload.
Vehicle: Suzuki Carry Van
Post Posted: Wed Feb 27, 2019 1:41 pm
G'day
I am also looking for a SJ50 or SJ80 rear crown wheel and pinion. I was about to post when I saw this one. Does anybody know a source for new ones. I have been ringing around and got no luck so far.
Regards
Chris from Dubbo.
Post Posted: Sat Mar 02, 2019 9:34 pm
I can help you with a RnP
feel free to contact me on 0437097475 Brad
Users browsing this forum: No registered users and 19 guests
