It is currently Fri Oct 23, 2026 12:06 am
Post Posted: Thu Oct 29, 2009 9:56 pm
hey guys got a question for those in the know. i am looking for a intake off a Vitara that faces the tb faward i am 95% sure i have seen one on here i need to know what year model they are off. and i did spend like 4-5 hrs searching the net for what i need to know
cheers guys
Post Posted: Thu Oct 29, 2009 9:57 pm
I think you are looking for the Baleno inlet.
Post Posted: Thu Oct 29, 2009 10:03 pm
haha maby do you know if they will run with the vit setup ecu injectors fuel rail ect?
Post Posted: Thu Oct 29, 2009 10:09 pm
If you can fit the Vit injectors in there it should work. You'll want to check if the throttle body will swap over or you might get lucky and they both use the same connector. If you just swap the manifold and all the other stuff stays the same it should still work and the ECU wont know any different.
Post Posted: Thu Oct 29, 2009 10:41 pm
oh ok then ill have to look into it. so there was no nit with that style intake?
Post Posted: Fri Oct 30, 2009 2:39 am
im curious.. why bother?
passenger side intake can be worked around
Post Posted: Fri Oct 30, 2009 3:06 am
Also the baleno runs MAP sensor, not MAF. So you may bave a hole to fill up the back of the baleno manifold.
Post Posted: Fri Oct 30, 2009 4:44 am
its for a swift with singel point injection its for my lil bro he wont to turbo it and you guys knwo vit motors better then any one haha
Post Posted: Fri Oct 30, 2009 6:18 pm
Vitara inlet mani is not going to work on a Swift head without some modification. The ports on the Vit head have a notch in the top of them that the injector (which is mounted in the inlet runner) fires into. You'd have to notch the Swift head out the same and also drill and tap some extra mounting holes as the inlet manifolds are different in that regard too.
Have a look at Wants33s recent post about 16v heads and you should be able to see the difference pretty easily.
Post Posted: Fri Oct 30, 2009 6:39 pm
the GV 1.6 efi also has the forward facing inlet manifold. Highway star has one
Post Posted: Sat Oct 31, 2009 3:03 am
wouldnt the vit manifold be better for a turbo?
unless you run an intercooler
Post Posted: Sat Oct 31, 2009 11:25 am
From a plumbing point of view I can see why he would want to use a mani with a forward facing throttle body. He can put an intercooler behind the grille and run a pipe from the outlet of the turbo into the intercooler, and outt he intercooler on the other side straight into the throttle body.
Users browsing this forum: No registered users and 120 guests
