It is currently Fri Oct 23, 2026 11:54 am
Vehicle: MY2019 Jimny
Post Posted: Sat Nov 07, 2009 6:56 pm
Is there a difference between mountings for WT and NT bull/tow bars?
Body mounts are the same, so I would assume that the bar mounts are the same...
Post Posted: Sat Nov 07, 2009 7:00 pm
Chassis width is the same, just a wider spring perch.
Should fit. :wink:
Post Posted: Sat Nov 07, 2009 7:12 pm
Dunno bout the bullbar but i know the tow bar will fit
Vehicle: 75 Cruiser
Post Posted: Sat Nov 07, 2009 7:24 pm
bullbars can be different, like the ARB bull bar, some mount to the outside of the chassis rail, so they wont fit a wide track because of the spring mounts.
Post Posted: Sat Nov 07, 2009 8:06 pm
SO if it mounts to the inside of the rail, it will fit both?
Post Posted: Sat Nov 07, 2009 8:12 pm
Yep, & as most modded zook's I've ever seen, the std mounting point's have been cut of to stop the tire's hitting it.
I can take pic's of one I" going to cut off if you want?
Post Posted: Sat Nov 07, 2009 8:15 pm
Nah it's cool Steknig, might cut into your postwhoring time...
ps Anyone wanna buy an alloy bullbar?
Post Posted: Sat Nov 07, 2009 8:18 pm
Just give me a reason to post again. :wink:
Post Posted: Sat Nov 07, 2009 10:49 pm
I might be interested depending on the style and price.
Also, am i correct in assuming it mounts to the standard (outside) points?
Post Posted: Sat Nov 07, 2009 11:17 pm
Yes it does - I'll put some pics up shortly...
It is a farking solid one too!
Post Posted: Sun Nov 08, 2009 12:30 am
http://www.auszookers.com/index.php?nam ... pic&t=7784
Go here.
Post Posted: Sun Nov 08, 2009 1:45 am
the bar in the link has custom brackets welded on
Users browsing this forum: No registered users and 130 guests
