It is currently Fri Oct 23, 2026 12:28 am
Post Posted: Mon Nov 02, 2009 9:23 pm
On Saturday I went into ARB to order my Front locker and 4 guys at ARB all told me I should do the rear first, so after doing all my research on front lockers and all the mods I have to do to fit it, I have decided, Fuck it!!! I'm just going to do them both.
Question! To fit to a 1999 GV 2.5lt V6 with 5.12 vit diffs
Which is the right one for the rear? RD74 or RD79?
Or is it RD88 both front and rear? !!!!!
Post Posted: Mon Nov 02, 2009 9:27 pm
depends on what vitara crown wheel you have
from my understanding RD74 = 10 Bolt (carby) & RD79 = 12bolt (EFI)
Vehicle: Sold zuk got a Bt50
how much is it costing you ??
bt50 now but still love the zooks
Post Posted: Mon Nov 02, 2009 9:39 pm
ARB have a deal on through November so for both lockers fitted to your centres, the compressor with tyre inflation, tyre inflation kit and tyre repair kit, then fitting and wiring yourself is $2790.00
Standard price for both lockers fitted to your centres and the small compresseor only is $3800.00
Post Posted: Mon Nov 02, 2009 9:41 pm
I believe I have the 12 bolt as the diffs arout of a 96 efi vit
Post Posted: Mon Nov 02, 2009 11:40 pm
that is very tempting but i should just wait till i get a few other things fixed b4 i get lockers
Post Posted: Sat Nov 07, 2009 3:18 am
So I've done the deed and bought both the front and rear lockers, now I'm guessing that the bit that attaches to your drive shafts is called the third member, so do I have to swap the third member on the front diff? GV steel third member to the vit 5.12 centre?
If your not breaking shit, try harder!!!
Vehicle: 97 SV420/627 SWB Vitara
Post Posted: Sat Nov 07, 2009 12:50 pm
Part #9 is your "third member" and if your GV is equipped with a steel one, dont change it. If yours is alloy, you can still fit a locker but the alloy ones are not known for their strength. Part #2 is your "Ring & Pinion" and are a matched pair. These you take from a donor Vitara with 5.125 diffs. These are the only bits you need to achieve 5.125 gearing in your GV front diff. The ring gear is attached to the ARB centre which make Parts 17 & 18 more or less redundant. If you are changing from an alloy third member to a steel one, most of the other stuff is swapped across. I would recommend installing a new pinion seal (part #7) if you end up putting in the 5.125 gearing
Lifted, Locked & Loud. Expensive Little Toy...
The 5.1 ring and pinion gears into GV carrier/ third member :wink:
Post Posted: Sat Nov 07, 2009 12:53 pm
Ah Stuey you beat me to it and with a better explanation.. :lol:
Post Posted: Sun Nov 08, 2009 6:52 am
Hey Mugwui since you getting front air lockers can i buy your Manual Hub Locks ???? :D :D :D :D
Post Posted: Sun Nov 08, 2009 4:04 pm
He still need's them :roll:
http://www.auszookers.com/index.php?nam ... pic&t=7790
Look here!! :wink:
Post Posted: Sun Nov 08, 2009 4:39 pm
steknig wrote:
beginner4x4 wrote:
Hey Mugwui since your getting front air lockers can i buy your Manual Hub Locks ???? :D :D :D :D
Look here!! :wink:
well there you go Ive learnt something going to need to change my name soon :rofl: :rofl:
Post Posted: Sun Nov 08, 2009 4:52 pm
Look here!! :wink:
To what? Understudy post whore?? :shocked: :finger:
Post Posted: Mon Nov 09, 2009 12:12 am
Hey beginner4x4, As the post whore say's, I still need them, But I do have another set here for sale off a vit I am wrecking. If you want them, PM me.
Post Posted: Mon Nov 09, 2009 12:18 am
Thanks for the info Stuey, Thats awsome. I'm a real hack at this, but learning every day and info + illistrations like that are perfect.
I've never pulled diffs out before but I figure if you dont give it a go then I will never pull diffs out and then I will never know...some one always knows how to put shit back together.......
Post Posted: Mon Nov 09, 2009 2:38 am
Your welcome. I didnt know a great deal about diffs either until around 6 months ago. It was then I went about looking into air lockers for mine and I thought if I could do most of the work myself it would save $$$. Its been a rapid learning curve since then.
All I can suggest is if you are pulling the diff out yourself, invest in new driveshaft and axle seals while you are at it. Only cost around $10-15 each. Piece of mind anyhow. But let a professional shop install the locker into the third member. This requires specialist tools and knowledge.
Users browsing this forum: No registered users and 173 guests
