It is currently Wed Oct 21, 2026 7:02 pm
Post Posted: Thu Nov 19, 2009 10:37 pm
hi my jimny is leaking water from the window sprayer when on a lean. Any ideas how to fix this
Thx
Doug
Post Posted: Thu Nov 19, 2009 11:01 pm
Mount the washer bottle lower in the engine bay or fit a restictor to the squirter hose (won't stop dribbly leak but will slow it a lot).
Vehicle: jimny
Post Posted: Thu Nov 19, 2009 11:13 pm
drain out the water
Post Posted: Thu Nov 19, 2009 11:41 pm
so is this a normal thing for them?
Doug
Post Posted: Fri Nov 20, 2009 12:34 am
If the bottle get as or higher than the nozzle, it will siphon out, any car will do it, my Gv's driver's side leak's if I go above 140kph (not on public road's)
:roll:
Post Posted: Fri Nov 20, 2009 1:35 am
rear squirter on my jimny used to leak, i disconnected the motor and the line
Post Posted: Fri Nov 20, 2009 3:10 am
My washer bottle leaks when doing endo's in the atari & the rear sprayer leaks when doing wheelies.
deal with it... it's a design feature so you know how steep you've been.
Post Posted: Fri Nov 20, 2009 3:12 am
I disconnected the motor. Only leaked after using it. If it can't be used it don't leak. Go figure
Our other Jimny doesn't leak at all
Users browsing this forum: No registered users and 140 guests
