[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Saam
Joined: Mon Jun 12, 2006 11:30 pm Posts: 2068 Location: Sunshine Coast
 Posted: Thu Nov 19, 2009 10:53 pm |
50mm spring
struts to suit
strut top flip
15mm spacers front
30mm spacers rear
50mm extended bump stops rear
15*8's with -20 something offset
30*9.5's
front guards chopped at the rear to allow for turning
would this work you rekon ? don't want to have to modify guards anymore.
also anyone running this setup, what rear shocks ?
sam
matty_wall
Joined: Sun Feb 15, 2009 10:30 pm Posts: 989 Location: Blue Mountains
Vehicle: SJ51T
 Posted: Thu Nov 19, 2009 11:01 pm |
i'd run 20mm spacers up front.. its supposed to be a 2:1 ratio but it never works out.
im running commodore shocks in the rear. works ok, spring get close to falling out when flexed. comfort goes out the window when you run them.
running longer travel struts and a strut mount flip may put the cvs in the danger zone.
prob other stuff but i dont remember. lol
royce
 Posted: Fri Nov 20, 2009 12:09 am |
XL7 front OME springs
OME struts, top flip
decent rear shock and bumpstops
Rear GV wagon springs and spacers to level it out
13x7 with - 13 or 0 offset
youll never clear that offset without a bodylift, its the inner guard (see where I am swinging that hammer) is where the outer corner of the tyre hits
Saam
 Posted: Fri Nov 20, 2009 12:55 am |
yeah that's completely bashed back to the firewall and the guard chopped back to suit before it was painted.
Saam
 Posted: Fri Nov 20, 2009 12:58 am |
it already has 50mm springs in it. and i have the 50mm bumpstops here already, i don't think he wants so spend much on it because it's not going to be used for hard offroading much..
JACKAL
Joined: Sun Nov 16, 2008 10:30 pm Posts: 28 Location: WA
 Posted: Fri Nov 20, 2009 6:25 pm |
i have 15x7 rims with -12 offset with 30x9.5.
had to knock back the guard mount as royce has said and grind the front bar a bit for clearance in the front.
rear needed the arch lip nocked up a bit. a 0 offset rim would of fitted better but this is pretty gd.
i have used rancho rear shocks to suit the new length from the lift. can have a look at there catelogue and pick one which suits your compressed/extended length
[ 6 posts ] |
Users browsing this forum: No registered users and 185 guests
