It is currently Sat Oct 24, 2026 4:19 pm
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1, 2, 3, 4
Post Posted: Tue Nov 10, 2009 2:25 am
the shim in pic 1 , to add preload , is not available as genuine suzuki part , it is an aftermarket part only. It would only be used to repair something that is very worn on the king pin , or swivel hub seal housing.
the shim in pic 2 , is available in genuine and aftermarket . It is only listed for lj and sj sierra applications , not in jimny .(although will fit)
Post Posted: Fri Nov 20, 2009 8:26 pm
So after a week of no wobble it had gradually come back so I went and sourced some shims. On test driving it all is good again.
Royce and Steknig I've not been able to find any spec on preloading the King Pins and nobody wants to volunteer there thoughts on the weight for testing so I've had to go the trial and error option. I've installed a 6 thou shim to each KP. I've measured the resistance with a fishing scale for future reference and will see how it goes. There was no binding or notchy feel while pivoting the hub back and forth.
Fingers crossed
Post Posted: Fri Nov 20, 2009 11:28 pm
& wobble? is it still there?
Have you ever replaced your rear bush in the front control arm's?
Post Posted: Sat Nov 21, 2009 12:39 am
Wobble is gone again. No I haven't replaced any control arm bushes, I'll get to them eventually but the fact that the wobble is gone again reinforces my belief that it's more to to with the KPs and maybe also from the wheel bearings. Passenger side definitely needs to be replaced. Another thing I'll get to.
besides it flexes so well with the old control arm bushes :lol: :roll: :lol: :wink:
Post Posted: Sat Nov 21, 2009 12:50 am
You have a Pm :roll: :roll:
Users browsing this forum: No registered users and 76 guests
