It is currently Sat Oct 24, 2026 6:37 am
Vehicle: 95 Sierra Soft top
Post Posted: Sat Nov 21, 2009 1:33 pm
Hey guys
Pretty new to the 4wd seen but i know what i want out of my zook,
"Tuff truck" If yous know what i mean,
I was on snake racing and eyeing off the CALMINI 5" lift kit, just want to know if any one has used this kit before and what will the overall hight be on the zook
ill be getting fatter wheels for it so should be ok the 5" i think lol
Oh by the way, is my zook a narrow track or wide ?? its a 1995 softop
Post Posted: Sat Nov 21, 2009 1:55 pm
I think you should hold off for a bit. It looks like you have a pretty clean rig there, fairly stock with a set of decent tyres. You will be very suprised where just that setup can get you.
My advice is to wheel it like it is for now. If you have some money burning a hole in your pocket, then a set of gears and a locker will get you much, much further than a $2k suspension kit.
Post Posted: Sat Nov 21, 2009 1:57 pm
Wide track... 5' is a fair bit buddy. Good luck with that
Post Posted: Sat Nov 21, 2009 2:22 pm
x 2
Post Posted: Sat Nov 21, 2009 2:23 pm
i run a calmini kit but i didn't fit the shackle reversal bit. dont listen to the haters as these springs and other components work well and have a great ride.
on my LWB i threw away the OME springs and fitted the calmini and got a significantly
better riding car.
just be aware that the springs do take a bit of running in but just load it up and go for a drive on a corrugated road. :lol:
if ya can just buy individual components get the springs and front spring plate/shock mount
things, plus run the calmini rear shocks with relocated top mount and use VS wagon shocks. on a SWB also use there rear shackles on the front or on a LWB use a set of fatzooks shackles.
you ger the same lift as a spoa but without the steering and axle wrap issues that come with a spoa lift. oopps also get two tailshaft spacers. :wink:
Post Posted: Sat Nov 21, 2009 2:40 pm
I'm not hatin', I just wouldn't pay $2k for that kit. There are other springs around that are proven on zooks for a whole lot less $.
Post Posted: Sat Nov 21, 2009 2:51 pm
I would auto lock the thing and get around on standard tyres for ages if i was you...
Post Posted: Sat Nov 21, 2009 3:22 pm
SAME MODEL AS MINE sj413 wide track =]
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Post Posted: Sat Nov 21, 2009 3:29 pm
also what the difference between an reverse shackle kit and a normal lift???
Vehicle: MY2019 Jimny
Post Posted: Sat Nov 21, 2009 3:44 pm
Normal lift doesn't relocate your front shackles.
5" is a real lot, and they like to fall over when up high...
Shackle reversal puts the shackle at the rear of the spring.
Post Posted: Sat Nov 21, 2009 9:30 pm
I ran this kit on my old zook and loved it but with 2 grand ya would be better off spending it on lockers and gears
nice zook by the way :D
drive the car like it is until you cant get to the places you want to go, then start to modify. You don't need massive flex in a sierra if you have lockers and gears.
Post Posted: Sat Nov 21, 2009 10:06 pm
Thanks for all the replys guys
But i have some spare cash to burn on it and was wanting to lift it, maybe for now i can get a body lift and airlockers for front and back, how much will i be looking at for airlockers fitted ??
Has anyone got ARB air lockers and are they any good ??
oh and how can you tell wide track to narrow ??
Cheers guys
Keith
Post Posted: Sat Nov 21, 2009 10:54 pm
I have an airlocker, it's awesome.
If you have spare coin, get some 6.5 crawler gears, a rear air locker and a mighty kong Tcase bucket.
Post Posted: Sat Nov 21, 2009 10:58 pm
If you don't need to lift it, then don't bother. A body lift will only be raising your centre of gravity for no benefit. It's usually only done to clear bigger tyres. ARB lockers will be approx $2500, you're best to call ARB and check.
Yes and yes 8)
Anything from approx 88 is WT. The most obvious sign is the metal (sometimes plastic) flares that were body coloured. Earlier models only had small plastic flares which were black.
Post Posted: Sat Nov 21, 2009 11:09 pm
lockers and gears would be the first things i do
Post Posted: Sat Nov 21, 2009 11:11 pm
2 inch spring lift & mudder's :roll:
Then go PLAY! :twisted: :twisted:
Post Posted: Sun Nov 22, 2009 4:15 pm
Looks like ill be calling ARB this Monday morning lol
2 thumbs up for the air lockers then,
thanks again for all your help guys hope to see some of yous out on the road ey
keith :wink:
Users browsing this forum: Google [Bot] and 141 guests
