It is currently Thu Oct 22, 2026 4:49 pm
Post Posted: Wed Nov 25, 2009 1:38 am
hey all, i got a prob. when i take off 1st gear sum times in second the transfur stick shutters(shakes side to side) only happenes like when u take off from the lights ect. hope to hear back soon it got me stuff wat it is i do have a rear mini spool if that helps.
2''lift 31's twin locked & 6.5s
Post Posted: Wed Nov 25, 2009 1:40 am
could be your uni joint or a transfer case mount may be broken
Post Posted: Wed Nov 25, 2009 1:48 am
ok kool thanks for the quick reply ill get it up on the hoist and have a look
anything else to look for ?
Post Posted: Wed Nov 25, 2009 1:53 am
check that the four bolts on the DS are tight as mine came loose and kept knocking itself out of gear... also would shudder as i took off...
Post Posted: Wed Nov 25, 2009 1:54 am
just check for wear on anything that moves
Post Posted: Wed Nov 25, 2009 1:58 am
ok then thanks ill look into it
Post Posted: Wed Nov 25, 2009 2:44 am
Seized uni joint in the jack shaft! :roll:
Post Posted: Thu Nov 26, 2009 1:56 am
jack shaft?
Post Posted: Thu Nov 26, 2009 2:00 am
drive shaft between the gear box and transfer case
Post Posted: Thu Nov 26, 2009 2:03 am
ok kool wat the easyest way to tell that its gone
Post Posted: Thu Nov 26, 2009 2:29 am
If a uni is flogged out u'll be able to feel a bit of slop by holding either side of it and turning it back and forth. I hope you can understand this lol
not sure how to tell if its seized in the car but u could pull it out it should move around fairly freely
Post Posted: Thu Nov 26, 2009 4:31 am
I was feelin those same vibes after giving the car abit of a work out . Simply crawled onder the car to notice the very shiney rubber on the gearbox mount give it a good push and hey presto broken gear box mount ! :cry:
I Like cat's they make good hats !
Users browsing this forum: AdsBot [Google] and 131 guests
