It is currently Fri Oct 23, 2026 11:37 am
Post Posted: Thu Nov 26, 2009 12:27 am
so i got some reduction gears given to me off a mate today problem is he doesn't know what ratio they are. So how can i tell ?
and once i know what ratio they are is there anywhere i can get a rear output gear as its stuffed
cheers
Post Posted: Thu Nov 26, 2009 12:34 am
Ouch hope u didnt pay much...
count the teeth and work it out..
or count the teeth and post up here some one will work it out for you!
Post Posted: Thu Nov 26, 2009 1:00 am
They were free so thats not a problem :D I wanted to try and use them in the LWB.
Ill count the teeth on the output shaft
edi: out put shaft has 26 teeth
Post Posted: Thu Nov 26, 2009 2:03 am
that looks like the INPUT shaft. not the rear output. if it's 4.16:1 ratio you can use the input gear from a 1 litre (with switch). of course getting hold of one might not be so easy.
but the question is WHAT has caused the damage? what is the mating gear's condition?
if theres any stamped names on the gears try to work out the brand and you might be able to buy just the buggered bits.
Post Posted: Thu Nov 26, 2009 2:09 am
they were not installed correctly so he replaced them the other gears have no damage ill take a look if there is any stamping i think they are 6.5 but i cant tell
Post Posted: Thu Nov 26, 2009 2:20 am
ok so i cant see anything stamped on the gears.
Also from what i can tell it is the input shaft can anyone identify it 100%?
Does anyone have a diagram of how to put it together i might be able to piece it together to tell what gear ratio it is by counting the turns
Post Posted: Thu Nov 26, 2009 2:36 am
count the teeth on each gear.
If you do this and tell me which gear has what number of teeth, I can tell you pretty quick what ratio it is. if you need to use pics, go for it :)
thats def the input gear/shaft too ;)
Clearance Hole Technology :P
Post Posted: Thu Nov 26, 2009 3:02 am
input is on the right. front output top left. rear output is on the bottom left
the gears that are all in line is the high range, the gears that feed through the intermediate cluster are the low range.
and the pic is a 4.16:1 ratio
Post Posted: Thu Nov 26, 2009 3:07 am
I'm uploading pics now but its taking ages each picture has the number of teeth written next to it i think i got them all
thanks so far
Post Posted: Thu Nov 26, 2009 3:37 am
ok the pics are upside down lol i used my phone i have no idea what order they go in if you cant read the numbers let me know
cheers
Post Posted: Thu Nov 26, 2009 9:59 am
Ill guess the low low's from ere, 1st pic, 6th from the top, 2nd from the bottom, 2nd from the top im pretty sure there is two of these. 4th from the top thats your 4wd selector, i think.... the big shaft thingo is what the front and rear output are connected to.
Download the off road lowrange 6.5's manual im sure you could figure it out from that...
Post Posted: Thu Nov 26, 2009 11:58 am
my lowrange 6.5 gears have a 26 tooth INPUT gear. the same as the one you have damaged. (1st pic)
your 7th is the same shaft just different ratio??
Post Posted: Thu Nov 26, 2009 2:54 pm
OK mate, you've got 2 sets of gears mixed up in those photos. there are actually only 5 "gears/cogs" in a Sierra transfer. You've also labbelled the selector parts as gears, they are just your 2-4 or H-L selector dog clutches.
I'll estimate which parts belong with which gears.
input gears: 26, 44
High range counter: 41, 58
High range output: 43
Low range counter: 23, 21
Low range output: 61, 60
none of these match a 1L Sierra case, some match a standard 1.3 case
standard 1,3 case:
input gear: 44
High range output: 62 (missing, or did you maybe miscount the 61 which I've listed as a low range gear? I'll assume this.)
Low range output: 56 (missing)
This leaves you with
input gears: 26
High range counter: 58
Low range counter: 21
Low range output: 60
therefore you get:
Primary reduction = 58/26 = 2.231:1
High range overdrive = 43/58 = 0.741:1
Low range reduction = 60/21 = 2.857:1
total high range = 1.654:1
total low range = 6.374:1
Numbers are not perfect, I'd say there is a miscount of teeth somewhere. But I think its close enough to say this is a 6.5 gear set. might be a 6.1, just depends on which way the error went.
Don't know how you'll go getting a new input. Contact whoever made the 6.5's maybe?
Post Posted: Thu Nov 26, 2009 4:20 pm
As they have all aready said count the teeth. But to add to that 6.5-1 you have to shave the case to get them to fitthe smaller ones you don't. secondly From what I have seen only rockhopper don't mark there gears with the brand name. They dont warranty there gear so they dont have to identify it. The fact that he didnt warranty them is also a strong suggestion that they are rockhoppers.
I have been building Gearboxs for a while now and I have never seen a gear come apart like that and now cause damage to the maiting gear. But good luck if you can get it in there cheap all the better. Just remember if you fit it into your case and it comes apart again you run the risk of cracking your case and cost you more money in the long run.
Post Posted: Thu Nov 26, 2009 4:22 pm
Trail Tough list a 6.4 set of t/case gears. Contact them to see if they will just supply a new Input Gear only. I don't know if these are the same tooth count as a 6.5 set, or if the others just round off their figures differently.
Looking at the pic of the gears you might to be able to count the teeth, but the design of the output gear looks very similar.
Post Posted: Thu Nov 26, 2009 4:51 pm
Didn't know there were 6.4's. well they might be the ones then, as the rounding makes sense :)
and yeah the 3 holes in the low range output gear looks very alike.
Post Posted: Fri Nov 27, 2009 1:10 am
I have been out fiddling with the gears again and took a look at the case i got with them. Both sides have been ground out to clear the gear so im certain they are 6.5 gears now i just have to find a input shaft
Thanks for the help fellas.
Post Posted: Fri Nov 27, 2009 3:56 am
zookster666 wrote:
I'm certain they are 6.5 gears now i just have to find a input shaft
So you don't think they are the Trail Tough 6.4's? I hope a 6.5 gear will mesh correctly.
Post Posted: Fri Nov 27, 2009 3:57 am
they could be ill ring the place he got them off and find out what brand gears they normally supply are
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 111 guests
