It is currently Fri Oct 23, 2026 12:53 am
Post Posted: Sat Nov 28, 2009 2:36 pm
how do you get it off? i have done 2 clutch's and never replaced this bearing as i couldn't get it off the spigot...
cheers
1200 8)
Post Posted: Sat Nov 28, 2009 2:52 pm
cheers
1200 8)
Is it in the crank?
Post Posted: Sat Nov 28, 2009 2:58 pm
Slide hammer. If you don't have access to one just make one
Post Posted: Sat Nov 28, 2009 3:02 pm
I was going to tell the bushman's trick of a hammer, a grease gun & a bolt.
But that will work. :roll:
Post Posted: Sat Nov 28, 2009 3:39 pm
grease + something that fits in the hole + hammer = a mess and a removed bearing :wink: :lol:
Post Posted: Sat Nov 28, 2009 3:40 pm
Never had any joy with that method. I found a length of threaded rod and a truck torque rod bush, couple washers and nuts and bingo. Just ground a groove at one end to hook into the bearing. It only works for small bearings though
Post Posted: Sat Nov 28, 2009 3:41 pm
Nothing wrong with a mess if the apprentice cleans it up.
Oooppps, I'm an apprentice now. :P :P 8O
Post Posted: Sat Nov 28, 2009 4:44 pm
sorry i may have used the wrong word, this is the bearing im refering to...
There is a slot on this side of the bearing where the fork is attached i can't get the bearing off the fork attachment....
thanks for all your replys fellas :D
Post Posted: Sat Nov 28, 2009 4:48 pm
Throw out bearing or clutch release bearing. If you pull it out as far as it will come then it just sorta twists off. You'll see the dowel on one side of the fork
Post Posted: Sat Nov 28, 2009 6:38 pm
Yep, can be a bit tricky but it will come.
Post Posted: Sat Nov 28, 2009 7:38 pm
Hmm maybe im not doing it right but i can't seem to get it off.... grrr
Post Posted: Sat Nov 28, 2009 10:58 pm
Pull it off the passneger side the jam a screwdriver down the drivers side of it and bam of it comes haha how do i know this? I did it today
TWIN LOCK IT & JUST DRIVE!
Post Posted: Sun Nov 29, 2009 12:33 am
must have some dirty teeths :O
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Users browsing this forum: AdsBot [Google], Google [Bot] and 185 guests
