It is currently Fri Oct 23, 2026 12:54 am
Post Posted: Thu Dec 10, 2009 3:27 am
i need one and want to know if i could use the gasket stuff that comes in a tube
Post Posted: Thu Dec 10, 2009 3:40 am
http://www.suzistore.com.au/shopexd.asp?id=131
Cost about the same as a tube of 3bond, you can just "glue" it on with 3bond or silicon, but that's what you are doing, gluing it on.
If it leak's again it will just be harder to get off to fix the original problem.
Post Posted: Thu Dec 10, 2009 3:43 am
great thanks stek
Post Posted: Thu Dec 10, 2009 4:15 am
coilyzook wrote:
great thanks stek
No worry's.
Post Posted: Thu Dec 10, 2009 12:03 pm
Glue, just use glue (automotive silicone) on everything unless it specifically requires a gasket like the head, or somewhere which uses thickness of gasket as part of its clearancing.
Post Posted: Thu Dec 10, 2009 12:06 pm
This is asking for trouble. I use sealant for sumps but dry gaskets for everything else
Post Posted: Thu Dec 10, 2009 12:21 pm
4j for everything else, only cause I like the smell :)
Post Posted: Thu Dec 10, 2009 3:24 pm
I use the gaskets and a very light coat of high temp gasket silicone.
That way it give great sealing, without being a total prick to pry off next time.
For things without gaskets i.e. diff, prying them off is a real pain in the bum.
Post Posted: Thu Dec 10, 2009 9:16 pm
gaskets with permatex non hardening sealant.
Post Posted: Thu Dec 10, 2009 9:28 pm
x2 shep.
gaskets with a smear of ultra grey
Don't worry, It's only a suzi...
http://www.auszo
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Fri Dec 11, 2009 1:27 am
i use silcone for eveyting :D
Post Posted: Fri Dec 11, 2009 3:59 am
So do I but not in place of a gasket if one is available, 3/4's of a modern ally eng is sealed with silicone, but thay are two machined surfaces, not tin on ally or tin on cast ect ect ect
Use silicone as an aid, not the fix (unless thay boobies) :P 8)
Post Posted: Fri Dec 11, 2009 10:47 am
I thought manufacturers like Toyota only use silicone for their sump gaskets. I did one only the other day. Even though it was a forklift, it had the same engine as a Toyota Dyna in it. Mind you, I don't know how Toyota produces it's sump gasket silicone. Once it sets, it becomes a job and a half to seperate the sump from the block again without damaging the lip of the sump. Have done a tb42 Nissan motor the same way too.
Post Posted: Fri Dec 11, 2009 11:02 pm
tb42? I try not to!!
I've broken a couple of sump's on swift's getting them off, but I was replacing them anyway due to the sump hitting something harder..
zd30 I've helped with a couple of time's, try not to tho.
Just about all the newer Suzuki eng's are mainly 3 bond gasket's, well sump & timing cover. But as said before, two machined surface's.
Post Posted: Sat Dec 12, 2009 1:04 am
Dee wrote:
x2 shep.
thats all I used on my gti sump :wink:
 Profile YIM
Vehicle: 85 SJ413
Post Posted: Sat Dec 12, 2009 4:59 pm
They come sealed with Silicon from the factory, and there is no sump gasket in the parts catalogue...
Suzuki Factory Service Manual wrote:
Oil Pan
1) Clean mating surfaces of oil pan and cylinder
block. Remove oil, old sealant, and dusts
from mating surfaces.
After cleaning, apply silicon type sealant to
oil pan mating surface continuously as
shown in Fig. 3-6-23.
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Users browsing this forum: AdsBot [Google], Google [Bot] and 187 guests
