It is currently Sat Jul 25, 2026 8:33 pm
Post Posted: Mon Dec 14, 2009 11:26 pm
My g16a in my Sierra is backfiring on deceleration it runs a Sierra head and carby what causes this carby or timing
Vehicle: jimny
Post Posted: Mon Dec 14, 2009 11:32 pm
an air leak
Post Posted: Mon Dec 14, 2009 11:49 pm
The thing is it doesn't have the characteristics of a vacuum leak it idles fine etc will look into it though
Vehicle: jimny
Post Posted: Mon Dec 14, 2009 11:57 pm
is it running lean so its popping on decel ?
im no mechanic
Post Posted: Tue Dec 15, 2009 12:03 am
Smells like it's running rich Im no mechanic either my 1.3 did it aswell but not as bad
Vehicle: jimny
Post Posted: Tue Dec 15, 2009 12:12 am
time to pm stekky, hey stekky get over here
Post Posted: Tue Dec 15, 2009 12:18 am
He'll be here sonner or later
Vehicle: jimny
Post Posted: Tue Dec 15, 2009 12:20 am
spamekky
Vehicle: 85 SJ413
Post Posted: Tue Dec 15, 2009 1:44 am
Exhaust leaks can cause backfires on decelleration. Stick your foot over the end of the exh and listen for a hiss from a leak.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Tue Dec 15, 2009 1:46 am
There are no exhaust leaks it might just need a good tune I'm picking up a 1.6 carb on the weekend see how that goes
Post Posted: Tue Dec 15, 2009 1:48 am
eldo wrote:
spamekky
Yes sweet pea?? :roll:
How bad is it?
What size exhaust do you have & how did you set the timing( if you did)
I found out the hard way that a car with a sport's exhaust will back fire on decell, most time's there is bugger all you can do about it, you said the 1.3 did it to.
eldo is partly right in saying look for vacc leak's, I'd also make sure the carby isn't over fueling, sucking or dribbling at idle.
I'm going to have to start charging you fuel money. :lol: :lol:
Post Posted: Tue Dec 15, 2009 2:39 am
burnt exhaust valves cause popping and backfiring, also exhaust leaks sucking in air in deceleration
Post Posted: Tue Dec 15, 2009 2:53 am
Ok I'll have a look at it the 1.3 was no where near as bad it doesn't worry me just thought it may be an easy fix it gas a 2 inch exhaust and extractors
Post Posted: Tue Dec 15, 2009 3:05 am
exhaust leak
retarded timing
rich
all of the above :)
some engines jsut put though, for no real reason
Post Posted: Tue Dec 15, 2009 3:37 am
I'll give it a tube do the timing put new carby on etc and see how that goes thanks for the help fellas learn something new everyday on here
Post Posted: Tue Dec 15, 2009 4:53 am
retarded timing
my moneys on that, but could be carby?
How is it on acceleraton?
255 characters
Post Posted: Tue Dec 15, 2009 2:50 pm
It's pretty sluggish on acceleration I'll have to get a timing light fm do that
Post Posted: Tue Dec 15, 2009 3:44 pm
A rich condition usually doesn't promote backfiring unless the timing is wayyy off. Since you have the 1.3 carb on the 1.6, find the idle mixture screw and set this to run the best at about 1k rpm. This is where the transition ports are just opening and where most of the problems occur.
Dan
Users browsing this forum: Google [Bot] and 537 guests
